  • Dot Guests: 247
Author Topic: VP 3.8v6 probs,how to get torque converter to lock  (Read 13267 times)
Offline Lyndon
« on: August 31, 2008, 10:06:47 PM »
need mechanics advice on how to get my vp3.8v6 motor thats in my bedford to lock, i was going pretty fast & loving the ride but the box was changing to third then to fourth then back again & annoying me big time, it must be a wire somewhere that locks it but where?
Lyndon
Re: VP 3.8v6 probs,how to get torque converter to lock
« Reply #1 on: August 31, 2008, 10:11:35 PM »
ask hammers.. i think he is the only mechanic here. but he charges $75 dollars a call for advice so try and fit it all into the one call..
Offline matty
« Reply #2 on: August 31, 2008, 10:30:25 PM »
I would think that the cable would need adjustment if thats possible. (I think they have a cable kick down) you may want to check to see if the cable is free
 from obstruction. I'm thinking that if the cable being caught on somthing it may be pulling it tight causing it to kick back.
  another issue could be a frayed or damaged cable not returning.
 Has this prob being there since you owned it or has it just developed as of late.
Offline Lyndon
« Reply #3 on: September 01, 2008, 01:50:17 AM »
thanks boys i was told that it was something to do with the wiring from computer, the trans is a t700 vp one.
Lyndon
hammers_spanners
« Reply #4 on: September 01, 2008, 10:22:40 AM »
Lyndon check the kickdown cable tension first. Also could be wiring issue or speed sensor in the trans.
Get onto ebay and buy a workshop manual on cd for a VN / VP as this will give you all the info you need.
If you cant find one on ebay let me know and I'll burn of 1 for you.
Hey Ben $75 is mates rates anyone else is $100 lol just kidding!!
Bren
« Reply #5 on: September 01, 2008, 04:18:19 PM »
T700's come out in two types.
one type has some electric solenoids where the other has
hydraulic valves of some sort.  not sure if this helps but the lockup converter
wont work if you don't have an auto computer.
more useless info is the T700 in an 84 Z28 camaro isnt the same and is almost impossible to
find, so dont buy a camaro with a stuffed T700 and think you can whack a commodore one in
there like i did.... :( thats how i found out there are two commodore ones.
hammers_spanners
« Reply #6 on: September 01, 2008, 05:38:00 PM »
Bren there's a lot of different T700 - R4 4L60 is a non electric from VN & VP - 4L60E is the electric version but with many types like 6HDD. If you are buying a 4L60E make sure the code is the same as the one you have!
I forgot to mention I have step by step DVD's to rebuild both 4L60 & 4L60E $40 for both inc postage
« Last Edit: September 01, 2008, 05:50:08 PM by hammers_spanners »
Bren
« Reply #7 on: September 02, 2008, 11:11:13 AM »
unfortunately the 84 Z28 has a torque bar off the gearbox housing that only suits a 305 camaro.....(bastards)
I really could have used that DVD a few months ago but i rebuilt it the ol' fashoined way....
with a book and an old man.
Offline Lyndon
« Reply #8 on: September 03, 2008, 10:29:09 PM »
all good but how do i know what t700 i have? theres lots of room under the beddy to get to it though.
Lyndon
hammers_spanners
« Reply #9 on: September 03, 2008, 10:37:14 PM »
I'll post some pix for you tomorrow.
