  • Dot Guests: 385
Author Topic: moving the motor  (Read 11403 times)
Re: moving the motor
« Reply #20 on: June 09, 2011, 04:42:05 PM »
Yes, I will keep the one in the V6 van where it is, but extend the intake to the box to the outside of the van, sure if you keep the air cold, better HP, but the Beddie goes well anyway with the V6 in it............
Offline gazza
« Reply #21 on: June 09, 2011, 07:07:03 PM »
the yellow one looks good
gsph
Offline matty
« Reply #22 on: June 10, 2011, 05:00:08 PM »
With moving the motor back I can only assume that the hand brake would all so have to move.
  So what are you guys thinking of doing with this small issue. I ask cause
I would like to put in a 1 piece bench seat in my van.
« Reply #23 on: June 10, 2011, 05:22:36 PM »
Mine sits on the engine cover but if you want to install a bench seat you could either mount one to the firewall and dash like a Falcon or mount one to the right hand side of the drivers seat.
