  • Dot Guests: 382
Author Topic: moving the motor  (Read 11401 times)
Offline jbeelitz
  • probationary
moving the motor
« on: June 06, 2011, 08:25:52 PM »
i have a 79 cf lwb with a 350 chev and turbo 400, 2 sparkplugs sit behind the extractors and have to split the car to get at. i want to drop the engine down and back,  would be good to pull the engine out through the side door, ha ha. who needs a tail shaft anyway.
plates have been handed in and wont be back till i have a brand new car.
everyone thinks i'm mad, i hope there wrong
any thoughts or ideas / elbow grease
where to start, that's easy
where to finish, who knows
Offline Zeeman
Re: moving the motor
« Reply #1 on: June 06, 2011, 08:40:47 PM »
There are two ways I would consider. The first involves cutting off the two engine mounts, swapping L and R and turn around 180 degrees.
Reweld right at the back of the crossmember. This should move the engine back a fair way, improving weight distribution & leaving penty of room for thermo fans etc.
The other way I've seen involved mounting the engine to the crossmember via a plate at the front of the engine. This drops the engine height so much you could almost use
a standard engine cover.
« Reply #2 on: June 07, 2011, 06:33:39 AM »
Done it. How far do you want to go back? I have a V6 sitting between the 2 front seats and put my engine in through the passenger door. BusyKiwi has a V8 sitting behind the front seats I think.
« Reply #3 on: June 07, 2011, 01:06:28 PM »
Gee, I have one mounted in front of the front seats ;D
Offline Zeeman
« Reply #4 on: June 07, 2011, 01:27:26 PM »
Here's a pic of a 350 mounted using the second method I mentioned:
Without the extractors in the way, the engine cover can be kept reasonably narrow.
My other thoughts are: You're not mad. But I hope you have plenty of time, and garage space, and money.
« Reply #5 on: June 07, 2011, 01:54:01 PM »
And here's the V6...
« Reply #6 on: June 07, 2011, 03:22:54 PM »
And here is mine, the mounts sit out in front of the cross member this allows the v6 to fit without cutting the floor any deeper, well pass the floor brace anyway.
« Last Edit: June 07, 2011, 03:32:45 PM by Bas / NZ »
Offline jimsvan
« Reply #7 on: June 07, 2011, 05:30:02 PM »
i like
« Reply #8 on: June 07, 2011, 06:41:24 PM »
heres mine :D
« Last Edit: June 07, 2011, 06:44:10 PM by BusyKiwi »
Offline Zeeman
« Reply #9 on: June 07, 2011, 07:41:05 PM »
You could always do this...
