  • Dot Guests: 68
Author Topic: Engine change  (Read 4075 times)
Engine change
« on: May 27, 2011, 09:04:01 PM »
Author  Message
petejamieson@bigpond.com
Member
Hello everyone,
new to the group, just picked up a 76' CF, I beleive. It had a Holden 186 engine in it which is a bit old, I have a 202 which I want to put in. Does anyone know the best way to do this, ie. through the front or out from under. Any info would be greatly appreciated.
Cheers!
petejamieson
 12 May 2004 @ 02:57
conrad
Member
  how i did it
the easiest way seems to be to unbolt the crossmember,
lift up the body (rotating about rear wheels)
then wheeling out the engine/crossmember/gearbox all in one go.
u can either make up a trolley to hold the thing level. or the easier way seems to be to put a trolley jack under the rear of the gearbox
to easy, dont forget your vitamins to help lift the body
 12 May 2004 @ 03:31
Nigzy
Member
  engine removal
How much is involved with removal of the Crossmember??How many bolts,Is it easy to get to them etc...
If the Vans a-rockin'...Dont bother knockin'!!!
 12 May 2004 @ 19:21
conrad
Member
  all this thinking, my brain hurts
ummm,
there are guys here that have done hundreds of these, ive done it twice so i might be making things up/ missing things.
>2 bolts each side above the wheels (i think they were for the actual crossmember.
>there are two long threaded rods (one each side, i think theyre called control arms) that need to be undone at the wheel end. these are a bitch later on since u have to hold them out of the way while u lift up the body.
>i had my steering column undone already, but u would probably need to undo that.
>brake lines probably need to be drained and undone from the calipers
>a good idea to drain out most of the tranny fluid, and the forward end of the driveshaft needs to come out of the gearbox (undo the yoke????)
>the gear shifter would have to go, as would the speedo cable.
>any wires that go to the battery or the dash
>fuel line
>mine didnt have one, but the heater hoses need to go. so do the radiator hoses.
>tranny cooler/oil cooler lines if you have them
how did i go? did i miss anything.
basically what i did was rig up a block and tackle to the beams of the shed, made up a brace out of rhs and put it under the chassis rails at the front of the engine bay. took the weight of the suspension, undid stuff till the crossmember was free, then lifted the beddie up as far as we could. dont forget to chock the back wheels!!
 13 May 2004 @ 00:44
Member
Thanks for the info Conrad.
Have checked a few things out and it seems that this is the way to go ie lift the front etc.
Will be doing it next week, after i've cleaned the 202 up and given it a lick of paint. I'll post a bit of a description of how things go when done.
Pete
 13 May 2004 @ 01:39
conrad
Member
  cheater
no worries,
should be a piece of p**s switching a 186 for a 202, should just bolt straight up.
bloody cheater, or maybe i just deliberately make things hard for myself
while we're on the topic, do u want a nice fibreglass engine cowl to go over your shiny new 202? anyone?
 13 May 2004 @ 01:43
Member
Whats an engine cowl?
 13 May 2004 @ 08:25
conrad
Member
  moo!!
no not an engine COW
an engine coow-l.
its an engine cover, um. the thingy that stops the engine being a cupholder while on long trips.
the thingy in the footwell.
sorry, i have a habit of making up my own words for things. is it actually called an engine cowl?
i dunno.
but yeah. its the large engine cover in the cabin.
i had to cut the bejesus outta my floor so its no good to me now. it was over the top of a 202 though.
i email u a pic if u want.
 14 May 2004 @ 00:29
JASON
Member
 could be a engine helmet?
or a thingyma whatsyacall it that covers the dooflakcy motorbittybit.
he he he we could go on all day couldnt we.
I call it an engine cover.
CHEERS JASON
 14 May 2004 @ 05:06
Gavin Gregg
Member
thats dam funny,
 14 May 2004 @ 10:52
Nigzy
Member
  engine cowl,cover,doohicky thingamajig
speaking of engine covers,anyone make one with cup holders moulded in,lol..just wondering
 19 May 2004 @ 00:03
Nigzy
Member
  more engine cover???
sound-proofing wise,does a fibre-glass cover cut down noise,or should i stick with the steel one??
 19 May 2004 @ 00:05
conrad
Member
  noise, WHAT NOISE??
um i have never had a steel cover.
but the fibreglass one made the sounds from the engine bay go much quieter (new word bonus!!)
although i wouldnt say that these sounds should be called noise, more like music
i remember the days when i would drive down the street without the cover on, with the air-filter removed.
USING A CAN OF AEROSTART LIKE NOS!!! haha!
tell me of another car that can do that!
 19 May 2004 @ 02:10
Member
Conrad
Thats some low bucks  High Preformance Mod's you had going
 19 May 2004 @ 04:05
conrad
Member
  thats wat happens when u watch fast&furious 2 much
i even considered putting some large washers on my shifter shaft.
cah-CHING, third
cah-CHING, fourth
(hits the aero-NOS)
psssh-ROOOAR!!
 19 May 2004 @ 04:36
Member
Have removed the engine as you guys said, it rolled out pretty damn easy. Only prob was the four bolts connecting to the chassy were a bit of a bitch, but persistance paid off. Took about 2 hours.
Will switch all the gear onto the 202 and plug it back in tommorrow.
 19 May 2004 @ 07:48
conrad
Member
  i feel ya
i had to let most of mine sit in WD-40 for a day,
i am really good at ripping the heads of bolts so im extra careful
keep us posted on the progress
 20 May 2004 @ 01:58
Member
When i pulled the engine out i noticed the rubbers on the control arm where it joins the chassi rail were a bit flat, does anyone have an answer to were i could get some new ones, and when looking for parts for the front end i've been told it is the same front end as another car such as a torana, ?? any clues
pete
 20 May 2004 @ 05:17
Member
   Weredoyagetit
try Scotts Old Auto Rubber
Scotts home page
www.scottsoldautorubber.com.au
Direct link to what you want
http://members.ozemail.com.au/~ausrov/BEDFORD%201977%20CFL%20VAN.htm
They did not have any in stock the other day so I just ordered some and they are mailing them to me.
Turn around time approx 1 week.
see this post for more info on the other bits.
http://www.buga.bedfordcf.com/funk/thread.php?id=248
 21 May 2004 @ 01:14
Member
Thanks for the help guys,
popped the 202 engine in, had no real dramas, pretty cool way to change an engine, heaps different to a VE Valiant. Now will just go through the rest of the beast and change any parts that need changing.
Thanks again.
pete jamieson
 03 Jun 2004 @ 02:59
conrad
Member
  its easy when u know how
just hope you didnt forget to put
a) oil
and
b) water
in, ive heard horror stories from people lately.
scary stuff
chev? holden?
« Reply #1 on: May 27, 2011, 09:08:51 PM »
aig
Member
things to consider, if your making a choice between installing a v8 into beddys the chev block has alot more narrow v to it than the holdens this gives more flore space back and makes changing plugs real easy too!
 23 Feb 2004 @ 13:21
Big Mark
Member
  spark plugs
I don't know what your setup is like but mine is a real pain in the butt to put it mildly I have a 350 chev in mine and I have extractors I don't have very much room at all and the bends on the extractors just make it that much harder to get to the plugs
It would be a diffrent story if I had headers instead of extractors it would be alot easyer
 04 Apr 2004 @ 17:29
conrad
Member
as far as floorspace goes,
i put the rb30 in, with extractors
and i had to cut heaps of the floor out.
i'll be lucky to squeeze a boot-clad foot onto the clutch pedal by the time i get an engine cover on. should be interesting
definitely something to consider when looking at an engine conversion
 06 Apr 2004 @ 06:08
Paul Andrew
Member
i have a 250 ford motor in mine
i didnt do the mod but its in there so yea
it's pretty large but there's an alright amount of room still
she's pretty quick off the lights for an old standard engine!
Beddy's are the coolest of all cool despite our troubles we still love them
 06 Apr 2004 @ 14:02
Dion
Member
   Cover fit
The v6 engine cover is quite large. I can just get my foot between the engine cover and the steering column. Thats why I went the auto. I put a couple of access wholes in the cover so I can check all oils and add if necessary with out taking off the whole cover. But if I do take the cover off everything on the engine is easily got at.
Dion
 08 May 2004 @ 00:24
Nigzy
Member
  253 v8 conversions
I have a 253 holden engine lying around,and just aquired a 72 cfs beddy.The V8 is sitting in a WB ute chassis.How much hassle to put the 253 into my van??Has any members here had experience with Holden V8 conversions...I have hundreds of questions...
 10 May 2004 @ 18:24
Chris Ryan
Moderator
Check out the Chev V8 conversion at:
http://www.reap.org.nz/~sullys/workshop01.html
 11 May 2004 @ 05:29
Anonymous
Unregistered
 05 May 2005 @ 15:17
Chris Ryan
Moderator
You will find a lot of info here. A 253 can be fitted fairly easily but you will need disc brakes on the front. Where do you hail from?
Chris
If at first you don't succeed, try a bigger hammer.
 06 May 2005 @ 09:05
cliff
Member
253 is easy to fit. Hardest part is making a new cover. I run a Toyota Supra 5spd, HQ discs on front, a 350 holley and Bosch elec. ign
Getting motor out & back in the easy way
« Reply #2 on: May 27, 2011, 09:13:02 PM »
Chris Ryan
Moderator
The best way to remove the motor from a Bedford is:
Make a trolley 6' long by 2' wide, put shopping trolley wheels on one end and make clamps to latch onto the frontend at the other end.
roll it under the van and latch to the rontend
undo gearbox crossmember and frontend, etc
lift body up at the front
roll out frontend, motor, gearbox as one unit.
I actually have 2 trolleys made and have a fresh frontend, motor, gearbox setup to go.
I can wip the old one out and the new one in and be going again in a couple of hours.
I will post a drawing for anyone interested
Chris
 24 Feb 2003 @ 21:37
Satyr
Member
Would love to see any drawings and photo's you have - of this and any other specialist pieces you have created.
Earl
 24 Feb 2003 @ 22:25
Chris Ryan
Moderator
I have emailed the info to Mark to be put on the web site. keep your eye out for it
 25 Feb 2003 @ 01:41
Mark Bartlam
Admin
Thanks Chris,
I have received the pics and will try to post them this weekend. This info is great and just the sort of thing I was hoping to get on the site.
Thanks again Chris and we will wait with baited breath for all your other insights and tips.
Regards, Mark
 25 Feb 2003 @ 10:44
snowflakes
Member
Just wondering if the pics of this trolley get posted, as I have to take my motor out and this sounds a great way
Regards Peter
 10 Aug 2005 @ 12:52
Chris Ryan
Moderator
Pictures can be found at:
http://groups.msn.com/BedfordVans/blackbedfordsvans.msnw?Page=2
I will mail them to you as well.
Chris
 12 Aug 2005 @ 02:24
snowflakes
Member
Hi,
Thanks for the pics Chris, helps heaps
Cheers Peter
 12 Aug 2005 @ 14:18
Marty
Member
  motor trolly
g/day chris , im Marty a new member, i currently have 3 beddy,s and 1 on the way.
and have to do 2 engine changes, that trolly sounds like a great idea, and i was hoping i could have a copy of the specs, . my email add is {hippymarty_69a@hotmail.com} it would make life easier, thanks cheers Marty
martyloves2party
 11 Sep 2005 @ 12:05
Chris Ryan
Moderator
It's on the way
Chris
 14 Sep 2005 @ 11:29
Marty
Member
  motor change
g/day, thanks, it will make life easier,
cheers Marty
martyloves2party
 24 Sep 2005 @ 12:24
wullie-d
Member
could i have a set of them to as im doing a change this week in scotland wullie-d@hotmail.co.uk
 03 Apr 2006 @ 18:21
Chris Ryan
Moderator
You will get all of the guff from:
My computer went toes up and I now have a laptop, so I dont have the stuff on it.
Chris
