Author Message
bedford
Member
Hi all,
Thanks for the help regarding the 3.8 install.
At this stage it is either going to be a holden 3.8 V6 or a late model ford straight 6 swap.
Just wondering if anyone has any photos or info on the ford straight 6 install so I can compare the two installs.
I read in another thread that Paul has a ford 250 motor in his van, just wondering if that is an OHC motor or still a pushrod motor? How much has been cut to fit the motor (photos would be great)
Daz
26 Apr 2004 @ 22:00
Paul Andrew
Member
ford 250 straight 6
hey daz,
i do have a ford 250 in my van.
i didnt do the mod myself so i dont kno evrything about it but i can tell u what i kno
its a ford 250 crossflow with an alloy head running on both gas and petrol. i think the engine's out of an XE/XF model ford falcon or similar. its currently being worked on and once i've got it back i'll take some good photos for ya ok?
hope this helps!
Paulie
Beddy's are the coolest of all cool despite our troubles we still love them
27 Apr 2004 @ 10:13
conrad
Member
i put in an RB30 straight six,
i could send photos if u want
might give u an idea of the kind of mods u would need to do
29 Apr 2004 @ 01:17
bedford
Member
Hi Paulie,
Thanks for the reply, pardon my ignorance regarding ford straight 6 motors but is the 250 motor in your van OHC, or did they go to ohc later?
Regardless I would really like to see any photos you can post/email of the engine install.
Daz
30 Apr 2004 @ 05:33
Paul Andrew
Member
engine type
i'm not heaps sure about what it is exactly as my knowledge isnt as good as most peoples but i dont think its an ohc one
i'm pretty sure they came later but i might be wrong
how can u tell?
u could try lookin on the net for what the XE/XF engines were exactly if u wanted to kno more
good luck!
i'll have photos maybe next week once i get her back from the mechanic etc ok?
Paulie
01 May 2004 @ 06:28
bedford
Member
Hi conrad and paul just wondering if you guys have had any luck getting photos of your engine installs, as I am eager to have a look.
Daz
25 May 2004 @ 02:18
conrad
Member
i have photos here,
where do i send em?
25 May 2004 @ 04:34
Paul Andrew
Member
Photos of ford 6
howdy
i have some photos i can send ya of mine
if u wanna take a looksy...let me kno
25 May 2004 @ 09:29
Member
Pics Please
Conrad
I'd love to see some pics of your conversion.
I have a 89 VL Belina donor car that Im thinking of using for Boris, so any info on engine & gearbox mounts mount etc would be greatly apreciated.
Paul A some of your Pics would be good to
yours in BUGAry
25 May 2004 @ 14:18
conrad
Member
um, yeah about the photos
i went through my archives
turns out i forget to take the camera for the day we did the mounts. i have a picture of use grinding off the old ones , but even a monkey can do that!
i was going to lift the van up again in the next few weeks to paint the crossmember. i can take shots then.
26 May 2004 @ 05:12
Nigzy
Member
photos of conversions
Hey You guys,I'd love to get any pics of ur engine swaps...My email is nigzy69@yahoo.com.au ...Any pics of Bedfords you wanna send me would be greatly appreciated! Also,check out my YahooGroup...
http://au.groups.yahoo.com/group/vantasticdreams ----------------------
If the Vans a-rockin'...Dont bother knockin'!!!
27 May 2004 @ 09:00
Nigzy
Member
250 falcon motor
Im trying to get any info on a Ford250 conversion with t-bar auto trans...whats the situation regards engine mounting,gearbox mounts,clearances etc..please,if anyone has photos or info Id love to hear from ya...NIGZ
06 Jun 2004 @ 20:21
Paul Andrew
Member
250ford stuff
will have some pics of whatever i can do for you as soon as i get some time to get round to it
didnt do the conversion myself but i can try to help
08 Jun 2004 @ 15:28
Paul Andrew
Member
250ford stuff
08 Jun 2004 @ 16:24
carnut1100
Member
That Falcon motor will be a pre OHC one. OHC came with the EA in 1988. The XD, XE, and XF had the alloy head OHV crossflow motor, initially with single choke Stromberg and later with twin choke Weber or Efi.
I don't know what it would entail converting a Bedford, but we run a 1969 Transit which was originally a V4, but when we got it there was an old Falcon 200 and 3 speed between the front seats. We got a long nose from a six cylinder Transit and converted it to XE crossflow and 4 speed from an XF.
We were lucky enough to use a factory crossmember but we had to measure it up and drill and bolt it to the chassis rails. You could probably cut the Bedford mounts off and use a couple of pieces of heavy flatbar to make two triangle shaped plates with a tube running between them. Falcon engine mounts will bolt to the tube, which should rune fore-aft. Gearbox crossmember is a piece of heavy flatbar which has been bent upwards at an angle either side of the Falcon gearbox mount andtheen teh ends are bent vertically to bolt to the sides of the chassis rails with gusset plates on the other sides of the rails. The 4 speed Falcon box shifter is a little far back for our liking, so we are looking at a Dyna box with a Falcon engine conversion bellhousing and a cable shifter.
The Falcon motor is great, lots of torque for towing etc, and it pulls a 3.5 diff easily and really wants something like a 3:1 for cruising, or a 5 speed.
We are running a Falcon diff at ethe moment, but it is too narrow, so we have to run deep dish rims. Also the beam axle is driving us crazy so we are looking at IFS setups that are easy to convert. One of the options onour list is the CF front end, as it is IFS and rack and pinion steering.
As for the wider diff, we are looking at F100, or maybe CF to match the wheel pattern from the CF front end if the CF can be easily converted to higher ratios.
Alternatively a Falcon axle can be widened easily. The axle tubes are different lengths on each side, so you can unpick the tack weld that holds the axle tube in place, remove the short one and fit a long axle and tube from another Falcon diff.
we are also considering 4 linking the diff and lowering the whole van by at least 2", maybe even 4". We run Falcon XY discs with HQ calipers on the front.
22 Nov 2004 @ 15:57
carnut1100
Member
Here is a site that shows step by step how to convert a CF to Chev 350 with photos of the process. The same technique would work for the Falcon motor, and it would be simpler as being a six there would be less cutting of the body.
This site shows clearly the type of engine mounts I am talking about, these would work just as well for a Falcon motor.
You couls also use the method shown here to fit a Falcon gearbox crossmember.
www.reap.org.nz/%7Esullys/workshop01.html ----------------------
22 Nov 2004 @ 16:06
Anonymous
Unregistered
I have converted 2 '78 CFS's to Holden 253 v8. Was going to use a Ford 250 on the second one but realised that the low part of the sump where the oil pump is would foul the crossmember. Hardest part of fitting a 253 is making a new engine cover. I also run a 5 spd Toyota Supra box, HQ discs on the front and a Ford 3.23 diff. The 253 has a Holley 350 and Bosch elect. ign.
05 May 2005 @ 14:57
bedford
Member
Hi guys,
Me again! I have been AWOL for a few months but I have been ticking over this conversion in my head all the while.
Paul Andrew: If you have any pics of your ford straight 6 installed I would like to see them, especially engine mount and engine sump shots (if you have them of course). You can send them to: bedfordvan@hotmail.com Thanks!
conrad: If you have since taken any shots of your Nissan straight 6 install into your beddy I would like to see those shots as well. Especially sump and engine/tranny mount pics. ty
Daz
