  • Dot Guests: 379
Author Topic: please help with a noise i can hear.  (Read 3614 times)
dan1989
« on: April 28, 2011, 09:54:28 PM »
hey i recently bought a 75 beddy cf. i have noticed a sound which seems to be coming from the rear of the car - perhaps the wheels. i hear the sound when i need to hit the gas to maintain a speed of roughly over 65km p/h. if i am traveling at arund 70km p/h and dont hit the gas i dont hear the sound but i obviously start to slow down. then if i hit the gas to maintain the speed i can hear the sound. please and help on what it may be and is it and easy and or cheap fix?? thanks all
Offline Numnutz
Re: please help with a noise i can hear.
« Reply #1 on: April 28, 2011, 10:36:56 PM »
put the van in neutral when you can hear the noise, if you can still hear the noise, most likely the diff gears are worn and may be close to failing.  :-\
« Reply #2 on: April 28, 2011, 11:23:21 PM »
What sort of sound ?
Things it could be.
exhaust  :D
Wheel Bearings
Diff bearings
Diff backlash
Universal Joints
Gearbox bearings
The Passanger screaming :o
Park the van, put the hand brake on, gut down on the ground and try to twist the tailshaft there sould be very little twisting, if there is try twisting back and forth the tail shaft while holding the yoke (one at a time) at each end of the tailshaft if there is any movement replace the uni.
If no movement then look at the backlash in the diff - do the same twisting motion to the tailshaft and see how much the yoke on the diff moves, a degree or two is OK any more can indicate a worn crown wheel and pinion.
Wheel bearings on the way out usually whine in a constant way increasing in pitch/noise as you go faster.
If your unsure allways replace the cheapest bit first ie uni joints before diff etc
I would hazard a guess and say the uni between the tailshaft & diff though.
Offline Worzel
« Reply #3 on: April 29, 2011, 08:00:13 AM »
If you have just bought it then you want to go over everything and get to know it.
Everything that you haven't checked is suspect
I would replace the unis and put a strap under the front end of the driveshaft, this one is just 30x3 steel.
