Hi fellas...Thanks for all your suggestions...wow...there a lot of possible things to cause this problem eh?
Well I had a look at the Oil level this morning and she is full and a nice honey colour, as she has hardly
done any miles since the last oil change..less than 100 I figure.
I tried to start her on LPG and she struggled to start..and wouldn't idle...kept on dying.
I gave her some revs and kept the idle up hoping she would come good when it got a bit warm
but was very lumpy and rough and finally died.
I tried again with a little adjustment on Dads advance device that moves the dizzy around a bit for
better performance on ULP and LPG see here if your interested.
http://gallery.oldholden.com/Jack_s/Adjustable+Distributor+Settings+whist+on+the+move/and this thread here
http://oldholden.com/node/27503#comment-110284I noticed the fan belt was squealing a bit when I gunned the revs so i will retention the fan belt at the alternator,
but doubt this is a factor of the probs...(everything happens in 3's so Im told)
Also I noticed the flashlube reservoir was empty ...so I bought a new bottle from Super-cheap Auto along with a new timing strobe light
& cylinder pressure meter kit oh my aching wallet ...credit card actually :'(
So after I refilled the Flashlube bottle I restarted her but still wouldn't idle...rough as guts...
I tried her on ULP and after pumping the gas peddle finally she coughed to life and hey presto...shes purring
away ever so nicely on ULP (petrol) I reset the lever on Dads gismo for ULP and the idle was nice and smooth.
So I drove her back in the drive way (not risking a run just yet in case i can make it back up the Hill where I live..
very steep (I reckon 16% grade or more...Its a bugger to walk up if your not fit ...like me
Anyway I stopped her, and flicked back to LPG and she stated but still rough and lumpy and dies..What the @#$..
Back inside for a cup of tea and a lie down and try to figure what is going on...most strange...
It could be the valve rods not set right as per one of the posts..I didn't know they where hydraulic lifters
I just thought they rod up and down on the cam and the "T" pieces and rocker covers tensioned down
kept them all nice and snug...Are all 202 fitted with Hydraulic lifters?...I didn't recall the workshop manual
say anything about resetting them one by one after the headgasket removal change over?
I will experment with the timing light to see if its all synced OK with the dizzy etc and to see if the mechanism dad made
does advance the light about and inch or or so back and forth which according to his notes equals 6 to 12 degrees.
Im in uncharterd territory here fellas..so bear with me
Then I guess I will take the engine cover off and test the compression of all the pots to rule out any possible damage
or enset of Valve seat Recession (VSR) ..boy I hope not...
Hey will this also tell me if I need to reset the valve push rods ? Or do I have to take the rocker cover off to do that?
Thanks again for all your suggestions and interest....I should be out enjoying the holiday eh..the joys of motoring and all that.
but sounds like i'm in good company eh?
