  • Dot Guests: 242
  • Dot Users: 1
  • Dot Users Online:
Author Topic: question about hway diff  (Read 7942 times)
Offline wazzah
« on: April 09, 2011, 04:40:48 PM »
Gday guys
I need a question answering,i'm fitting a hway diff with a borg warner centre into my swb autobox van,when i got the diff it came with a prop shaft made but its to long.way to long..so can i use the old prop shaft off my old diff? it seems to fit the borg warner flange ok but seems to be a little shorter in length when i bolt it all together...
 when the original diff was in the flange sat right up to the seal at the back of the box,now it sits about 5-10cm away is this a problem?
see pics..or do i have to get a new diff made up?
also do you think i would get the van road worthly with a frt disc conversion and jelly bean mags on it here in brisbane???
thanks guys
build it and they will come
Re: question about hway diff
« Reply #1 on: April 09, 2011, 05:05:04 PM »
Hey Wazzah that looks fine to me there is still plenty of shaft up in the bearing Use that one
Offline jesus_is_alright
« Reply #2 on: April 09, 2011, 05:22:21 PM »
5-10cm or 5-10mm? Centimetres, no, milimeters, yes.
When i measured to get my prop shaft made up, my instruction was
1. Fully seat the slip yoke in the transmission
2. Pull it out 25mm
3. Measure the length
this 25mm allows the shaft to move "in" when you go over bumps (and also move out)
-Aaron
Offline JOE RYAN
« Reply #3 on: April 09, 2011, 05:43:57 PM »
Wazzah
I had a new tail shaft made about 3 years ago, just measured mine, from rear of extention housing of gearbox to face of yoke same as your second picture 48mm.
had no problems
Cheere
Joe
« Reply #4 on: April 10, 2011, 08:27:48 AM »
I had one made last year, I know buga all on how to do it  ;D ;D I got the guy that builds them to measure it up.  ;) ;) ;D He delivered straight to my door.  ;D ;D
Offline wazzah
« Reply #5 on: April 10, 2011, 09:19:48 PM »
cheers guys thanks alot for the advise be stuck with out it ;D
think ill go with the original prop and see how we go ;D wish me luck.haha
George do you know somewhere in brisbane that can convert my diff to hq stud pattern??
Thanks again boys
« Reply #6 on: April 11, 2011, 09:09:00 AM »
Hey Wazza, i dont, but give this guy a call he may be able to put you onto the right people. 0417400920 ask for anthony. Mention my name and he will help you out.
Offline Marky
« Reply #7 on: April 11, 2011, 11:30:27 AM »
hey wazza
make sure you get the tailshaft balanced...makes heaps of difference
Creative Media Producer
« Reply #8 on: April 11, 2011, 03:43:25 PM »
don't forget the tailshaft loop!!!!    deadly without one :o
