  • Dot Guests: 340
Author Topic: master cylinder  (Read 14066 times)
Offline wazzah
master cylinder
« on: March 31, 2011, 06:56:34 PM »
Gday guys
Was wishing and hoping you guys can help me.I"m converting my swb mk1 to front hq disc and pbr calipers ,i have done the disc conversion (thanks ben) ;D..but now i need to do the master cylinder and find some brake pipes for the caliper.. ??? ???
 Ive read most of the post and all you guys seem to have fitted different  cylinders and have different opinions on which is the best system to use..can you guys help to fit the best and easiest master cylinder...pretty please  ;D
thanks guys
wazzah
build it and they will come
Re: master cylinder
« Reply #1 on: March 31, 2011, 08:12:14 PM »
Hey Wazzah I found the standard master cylinder works just fine if its stuffed just get it rebuilt
Re: master cylinder
« Reply #2 on: March 31, 2011, 09:46:28 PM »
mine is an XA falcon - or maybe a XB..
disc front drum rear, but i have the f100 drums on the rear of my van..
not sure what is involved in the conversion as my van had this setup when i got it, i've just replaced the current setup with newer parts.
Offline JOE RYAN
Re: master cylinder
« Reply #3 on: April 01, 2011, 09:25:49 AM »
Wazzah
I did a similar conversion, I had one of those mobile hose guys make me up two flexible hoses to go from bedford pipe work on van into the HQ caliper, and had my standard Bedford Master cylinder resleeved. The only comment that I would offer in that the bore on the Bedford master is a bit small and there is more brake pedal travel to get the sufficient volumne of fluid into the calipers. I intend replacing brake master with early commodore master.
Joe
Re: master cylinder
« Reply #4 on: April 01, 2011, 03:53:19 PM »
hey Joe, I used a HQ master cylinder, overcame the extra rod travel by placing a 1/2" nut in front of the rod, solved the excessive travel issue and works like a gem  ;)
Offline wazzah
Re: master cylinder
« Reply #5 on: April 04, 2011, 06:45:58 PM »
Thanks guys for your advice,i think i'll give the hq master cylinder a go..
Thanks again for the advice ;D ;D
Re: master cylinder
« Reply #6 on: April 04, 2011, 08:31:49 PM »
youll just have to do something with the clip that holds the cap on the hq master cause it will cause your bonnet to sit up. cheers ben
Offline grandad
Re: master cylinder
« Reply #7 on: April 04, 2011, 09:25:17 PM »
big hammer will fix the bonnet  ;D
Offline Numnutz
Re: master cylinder
« Reply #8 on: April 05, 2011, 11:20:16 PM »
I can't remember what mine is off, but it clears the bonnet with out any modifications.
It was off some small jap car, toyota corona maybe???
I spent ages at a wreckers looking under all the bonnets, trying to find where it came from.
I did find it, but silly me didn't write it down, and forgot
Re: master cylinder
« Reply #9 on: April 06, 2011, 01:39:23 AM »
std beddie master cylinder should be fine mines pretty awesome stops on a dime . with 11'' rear drums.
