  • Dot Guests: 83
Author Topic: Daily Post  (Read 1290702 times)
0 Members and 7 Guests are viewing this topic.
« Reply #820 on: September 25, 2012, 12:12:28 PM »
A duel wheel diff, Gee they are Heavy Duty, well on the outside anyway...........
« Reply #821 on: September 25, 2012, 01:07:38 PM »
that looks like a ford centre
« Reply #822 on: September 25, 2012, 04:03:01 PM »
Ok, didn't look that close.......
« Reply #823 on: September 26, 2012, 02:17:43 AM »
so it could have just failed where the welds were. how is the diff conversion done? just but welded? could be a problem.
« Reply #824 on: September 26, 2012, 07:19:45 AM »
If it was converted it should of been joined further out. The old axle tubes are usually turned down and pressed into the head tube and welded.
from factory the tubes are plug and seam welded. without knowing the full story it looks like the factory weld broke at the bottom causing the case to split. thats a lot of pressure to do that though.
A diff under pressure usually goes out of alignment and snaps the axles at the spline
« Reply #825 on: September 26, 2012, 03:02:07 PM »
I would suggest bracing it like they do for competition 4x4s
« Reply #826 on: September 26, 2012, 06:37:38 PM »
« Last Edit: September 26, 2012, 07:03:32 PM by Bas / NZ »
Offline Hobbit
« Reply #827 on: September 27, 2012, 09:12:49 AM »
G'day Bas,
Great collection of photos, man. Love 'em.  8)
I particularly like the front on the van in the last pic.
Keep up the good work.  Cheers.
« Reply #828 on: September 27, 2012, 11:31:44 AM »
Found the missing GREEN one.............it's here in NZ
« Last Edit: September 27, 2012, 11:34:18 AM by Bas / NZ »
« Reply #829 on: September 27, 2012, 06:16:39 PM »
hmmmmmmm bas  :-\     dunno,...... what do you reckon george  ::) , think its our fabled  :o missin green van  :o ???
