  • Dot Guests: 85
Author Topic: Transit Power Steering Rack  (Read 92402 times)
Re: Transit Power Steering Rack
« Reply #60 on: February 07, 2012, 02:05:34 PM »
Hmmmm, thinking about it you might want to confirm that it will fit first too depending on where your engine sits. Mine is midmounted so my bracket was made up without that as a consideration in the fitting. Also my van is a later model that yours so there might be a gotcha there as well.
Good thinking, I don't think you could have a stock mounting bracket as so many engine swaps a different, / backward mount- High mount- low mount - forward mount like mine, all will have an effect on the mounting of the power steering, unless you go mid mount like you.
Offline tiwaz_nz
« Reply #61 on: February 07, 2012, 07:53:19 PM »
think i have plenty of room around the steering rack ... have posted pics in gallary .. not sure how to post here yet  ???
was hoping for some sort of plan , i have a spare cf2 front end will use cardboard to make a template and get my son to make at work , but would be keen on a price to compere
« Reply #62 on: February 07, 2012, 07:58:52 PM »
Your rack has been moved forward by the looks of it, or might be the angle of the picture.
« Last Edit: February 07, 2012, 08:02:21 PM by Bas / NZ »
Offline tiwaz_nz
« Reply #63 on: February 07, 2012, 08:09:03 PM »
must be the angle .. the brackets dont looked to be changed will compere with the other steering rack i have ...
 tho its off a much newer van
Offline tiwaz_nz
« Last Edit: February 07, 2012, 11:47:18 PM by Warren »
« Reply #65 on: February 08, 2012, 03:24:58 AM »
It does look different. I'm sure mine had nowhere near that size gap between the rack and the front crossmember.
« Reply #66 on: April 14, 2013, 12:39:37 PM »
Hi Rogue and other Transit power rack converters. Scored myself a rack at Pick-a-Part earlier today so I'm about to join the assisted steering club. Had a sudden though and figured you fellows would know the answer. I left the Transit universal joint and short steering rod back in the yard. Do I need it ?
« Reply #67 on: April 14, 2013, 12:59:25 PM »
Yep. We used it.
« Reply #68 on: April 14, 2013, 03:52:55 PM »
Don't forget, you need the longer rack of the 2....
« Reply #69 on: April 14, 2013, 04:21:51 PM »
Thanks Rogue, I'll go through and fetch it next weekend.
