  • Dot Guests: 99
Author Topic: Transit Power Steering Rack  (Read 91050 times)
Re: Transit Power Steering Rack
« Reply #10 on: February 15, 2011, 10:23:14 AM »
Hey Rogue, ok my bracket is bolted to the crossmember, but i was able to get some more detailed pics, and i have labeled each pic, so if you have any Qs. just ask and i should be able to answer. The one thing i have done with my van is be involved with every modification, so i know everything about whats done. Give me an hr or so, and i will have a power steering section in my album, but here is some more pics for you.
« Reply #11 on: February 15, 2011, 10:26:43 AM »
and more, We still need to sandblast and paint or powdercoat. Hope these help.
« Reply #12 on: February 15, 2011, 12:07:09 PM »
Hey guys, ok I have done up an album for the power steering rack, there are still a lot of bits i have to add to it, but i have started.
« Reply #13 on: February 15, 2011, 06:59:15 PM »
Hi George...Thanks for the great pics mate  ;D it gives me a good idea what to look out for !!!
Offline beddymad
  • new project
« Reply #14 on: February 15, 2011, 07:15:02 PM »
thanks george your a top bloke :D
« Reply #15 on: February 15, 2011, 07:54:02 PM »
excellent George thanks
« Reply #16 on: February 15, 2011, 08:21:08 PM »
Hey George those tirods are they transit ones shortend with beddie thread on the ends or custom built & iff so where do you get them Cheers Reid
« Reply #17 on: February 15, 2011, 08:45:35 PM »
Hey reid, no mate they are custom one offs, an engineering mob up her in queensland machined them up from raw steel. They actually made them thicker and shorter then the original beddy ones. These were made to screw onto the transit rack with a thread that accepts the standard tie rod ends, which are new ones. I think it was TBS, check the disc brake thread from last week, and i have their details on there. The guy at TBS knows about beddy's so he knows exactly what to do.
« Reply #18 on: February 15, 2011, 08:51:25 PM »
i just tried to find the disc brake posts but can't, i had the contact details in there, so if someone can find it for me.
« Reply #19 on: February 16, 2011, 01:00:19 AM »
top thread lads, thanks, now , I have a couple of Q's,
turning circle? i remember reading it was a little larger , but nothing really to worry about , can anyone remember or enlighten us.
pump? what pumps are being used , I have a chevy std pump, assuming its similar if not same as holden/ is there any pressure ratio's to be aware of?
cheers Dano
