  • Dot Guests: 375
Author Topic: Cleaning Cooling systems  (Read 4115 times)
« on: January 27, 2011, 01:16:45 PM »
I was surfing the interweb and found this link
Collant system fix
It came up in conversation with Fank yesterday so I thought I'd post it so others could see it as well.
"Professional cooling system de-scaling is done with Sulphamic acid for hard water, lime and antifreeze build up. Oxalic acid is used to remove rust.
Sulphamic acid crystals are available at the hardware store in form of 'grout and tile cleaner'.
Oxalic acid crystals are available in form of 'wood bleach'."
Possibly just the Oxalic acid crystals could be used for a overheating beddy, but it seems to be a simple proccess doing both.
See post #20 for more info
« Last Edit: January 27, 2011, 01:20:40 PM by Warren »
Offline Bedford Fever
Re: Cleaning Cooling systems
« Reply #1 on: January 28, 2011, 01:03:18 PM »
Thankyou Warren , I will try that method and let you know how I go.
