  • Dot Guests: 278
Author Topic: bedford 9inch diff conversion  (Read 10972 times)
Re: bedford 9inch diff conversion
« Reply #10 on: January 06, 2011, 04:39:32 AM »
also if anyone is looking for front seat belts for a cf the the ones out of a Big Horn fit the same as a retractible bedford on & have long stalks.
replace some on my uncles cf350 van..
work fine
« Reply #11 on: January 06, 2011, 05:58:20 AM »
Thanks David. I have PM'ed you re your diff centre. Cheers Gordon
« Reply #12 on: January 06, 2011, 09:53:30 AM »
work fine
Dumb question...
What's a Big Horn?
and yes I know... LOUD.
« Reply #13 on: January 06, 2011, 10:07:41 AM »
Ya beat me to the same question Chris ;D ;D
« Reply #14 on: January 06, 2011, 11:08:21 AM »
Bighorn in Kiwi land is put out by Mitsubishi, eg: Pajero / Bighorn
« Reply #15 on: January 06, 2011, 12:32:15 PM »
I thought the Bighorn was Isuzu...  ???
« Reply #16 on: January 06, 2011, 01:24:59 PM »
YES YOU ARE RIGHT, YOU CAN SEE I DON'T HAVE ONE...............
« Reply #17 on: January 06, 2011, 04:06:39 PM »
G'day
Looks like a Jackaroo to me:
Offline Banksx2
  • Willagee WA
« Reply #18 on: January 06, 2011, 06:18:40 PM »
the width of the diff is 1620mm plus has 10mm spacers as well.it was on my van with standard holden wheels and was perfect.as for bolt pattern you can get spacers with different bolt patterns which just bolt on.
Is the 1620mm from inside of drum to inside of drum?
Garry
Offline beddymad
  • new project
« Reply #19 on: January 06, 2011, 09:21:14 PM »
no its approx from outside of drum to outside of drum.it was in my shortwheel base and had standard hq wheels and was perfect with the spacers that came with it.without the spacers you would be able to legally put wider wheels
