  • Dot Guests: 94
Author Topic: custom made drop spindles?  (Read 18346 times)
Re: custom made drop spindles?
« Reply #10 on: November 28, 2010, 04:34:43 PM »
graft Jag control arms to the bedi subframe far better ride/handling stub is higher up the post big killer brakes & holden stud pattern what more could you want. Craig posted picks of mine awhile back
« Reply #11 on: November 28, 2010, 07:35:38 PM »
any details on how to do it...
« Reply #12 on: November 28, 2010, 09:04:13 PM »
I COULD tell ya but then i'd have ta kill ya  ;) as i said theres some pics on here somewhere . I spent over 360 hours on developing it . it has 3 track widths and is fully adjustable but you dont have to bo so elaborate
Offline outriding
« Reply #13 on: November 29, 2010, 09:17:38 PM »
seriously consider a different way of lowering beddy.
here is what i will do when it comes time i want to lower a beddy,
cutinto the chassis, lower body down, re weld, strenthen with something substacial, put lwb springs in to stiffen up front.
yoy could get shorter springs, then move wishbones to compensate. plenty of ways.
or... graft a different front end into yor van.
jack up your van and stare at it for 12 hours and im sure youll think of plenty of other ways.
stub axels should not be tampered with and i would look at a way to do it while using orig ones.
That is a whole lot of work ben!
Why would you spend endless hours of work hacking up the frame when you can achieve the same result in a simple axle swap?
In the vw bus world the drop axle is a comun practise.
I see no problem as long as the new or modified axle is made correctly.
« Reply #14 on: November 30, 2010, 01:25:24 AM »
OK, lads, got a phone call this morning from Rod Hadfield himself .he spent 2 days ,last w/end finding all or most of his paperwork/notes/jigs for the bedford drop spindles. long story short..... he is prepared to do a run of 6 pairs this run,more of more wanted...
BUT  we need to let him know numbers asap as these will take afew months to complete ...and they are included in the run of approx 150 other spindles    WHICH THEY ARE POORING? NEXT MONTH...
i need to write a full post to explain more but don't have time this sec....sorry....
COSTS..... virgin hubbs $770
                   plates,setting in,machining,welding,drilling,tapping,freight etc, again I'll explain more ,(hopefully tomorrow) roughly the same, soooo, around $14-1500 mark. these are run from the same mill as holdens/ford current mill and will be rta approved and certified with all papers and docs.
Dan
« Reply #15 on: November 30, 2010, 01:50:09 AM »
wow.....
i dont want a set that bad..
Offline Sweet Shock
« Reply #16 on: November 30, 2010, 08:41:00 AM »
Any body got any pics with a bed with drop axles
« Reply #17 on: November 30, 2010, 02:52:44 PM »
« Last Edit: November 30, 2010, 02:56:26 PM by obsession »
Offline Sweet Shock
« Reply #18 on: November 30, 2010, 03:46:03 PM »
Have you got a pic underneath pete
« Reply #19 on: November 30, 2010, 04:21:13 PM »
yes it is an interesting set up the top wishbone has been shifted outwards to fix camber Im not sure about it yet but it did turn ok .
having a drama up loading it to ph bkt at the moment.
« Last Edit: November 30, 2010, 04:48:11 PM by obsession »
