  • Dot Guests: 309
Author Topic: what wires needed just to get the motor to turn over?  (Read 8177 times)
« on: November 21, 2010, 02:30:02 PM »
at the moment i have no wires connected what so ever in my 202 and have put a blue dizzy and a slime line starter from another model.
i just need a quick guide to be able to kick the motor over that does not have to run through the dash as the dash is all removed.
just battery and starter if possible.....
thanx.
Re: what wires needed just to get the motor to turn over?
« Reply #1 on: November 21, 2010, 06:23:07 PM »
Buga just wrote it all up and lost it.
Try again
Do you want the motor to just crank over or run ?
to just crank over you need two ciruits - the main power cct and a starting/switching cct.
First the main power cct - heavy cable from the +ve of the battery to the large +ve post( 8mm bolt thingie) on the starter soleniod, and another large cable from the -ve post to ground, either direct back to the batter or to ground on the chassis.
Now a switching cct - lighter wire from the +ve of the battery with an in line toggle or momentry switch to the +ve bayonet connector om the soleniod close to the posts, and from the -ve bayonet connector back to earth or -ve of the battery.
Press the moonetry switch or flip the toggle and you should have movment - just be carefull as you dont have any fuses in the ccts.
If you want it to run you need another switching cct to the coil - same as the starter switching cct - but this time just a toggle switch will do - from +ve on the battery via a toggle to the +ve connrctor on the coil and from the -ve to earth (or battery)
read the wireing diagram and only look at the cct from the battery to the starter to hel visualise what Im saying.
hope this helps Warren
If you
« Reply #2 on: November 22, 2010, 03:48:50 PM »
thanks warren! yep it was just to crank.
« Reply #3 on: November 22, 2010, 07:22:58 PM »
sorry to highjack post but same/same...... 350 chev, std ignition, new pts .019gap, new condenser, new coil, still no spark??.... not even a crackle at the points.... is dizzy .... u/s?
Dan
« Reply #4 on: November 22, 2010, 08:01:15 PM »
Dano, just try a wire from positive batt., to positive coil and see if you have spark, before you turf the dissy
« Reply #5 on: November 22, 2010, 08:55:48 PM »
Dano check the small earth strap in the dizzy is connected and also check you haven't got the points wire on the wrong side of the insulator and try dropping the gap to 16 thou if you still get nothing and you got 12 v at the pos side of coil I 'd say your coil is cactus
« Reply #6 on: November 22, 2010, 08:59:11 PM »
I agree bypass all the ignition cicuitry as I stated earlier
This will isolate all your harnesses ignition cct, and if it starts - go looking further - if it dont - get another dizzy.
*Edit Merlin got in before me - yeah the coil could be an issue too.
Always replace the cheapest part first.
« Last Edit: November 22, 2010, 09:01:09 PM by Warren »
« Reply #7 on: November 24, 2010, 07:16:30 PM »
ok thanks lads, i do have power right to the points, just going to try 16th + earth return to batt, me thinks an earthing prob. the dizz base plate seems a little loose (points  screw to) and i can move the little weights / cam lobes is this correct? (just a toggle to open /close points)
dano
« Reply #8 on: November 24, 2010, 09:37:52 PM »
Dano
Those little weights are the mechanical advance units they move the shaft as the revs increase the centrafugal force forces the cam lobes around, advancing? the timing.
So you should be able to move the shaft 5 or so degrees.
« Last Edit: November 24, 2010, 09:40:50 PM by Warren »
« Reply #9 on: November 24, 2010, 11:35:02 PM »
Ok,was able to finally get a good spark at the points, using my supa coil, and direct + from batt to pos coil,changed back to new old coil and the spark was there but seemed weak, changed back to supa coil and fitted dizzycap and lead, laid lead to floor/earth to check spark and seemed weak, tested lead, 6.82 resistance,??? and by this time the batt was getting tied so went out to get new batt but nothing open.......cracked a burbon kicked the kin thing and went inside...... :D
2morro....dam it!
« Last Edit: November 24, 2010, 11:36:59 PM by Dano »
