  • Dot Guests: 251
Author Topic: cresta Diff gears  (Read 3966 times)
Offline LS120
cresta Diff gears
« on: November 13, 2010, 06:56:44 AM »
ok people i have my old bedford diff head with the cresta Gears inside all ok just needs new pinion bearing..
have had a holden put in & now dont need it.
it's in NZ sorry guys... but if you want it i can strip out the gears and send over..
i'm looking at about $200. nz + P&P
PM me if you are inturested
thanks
David
Re: cresta Diff gears
« Reply #1 on: November 13, 2010, 12:02:16 PM »
what ratio are the gears fella?
Offline LS120
« Reply #2 on: November 13, 2010, 07:32:17 PM »
3.1:1 or 3.2:1 from memory...
Offline Jeff
« Reply #3 on: November 13, 2010, 09:21:16 PM »
Are there different ratios?
My Cresta diff is 3.5something to one....or is that 3.4something?
Funny old life.
Offline LS120
« Reply #4 on: November 14, 2010, 12:41:28 PM »
yes there was.. one was for the Automatics & the other for the Manuals
« Reply #5 on: November 14, 2010, 04:14:00 PM »
Manuals were 3.9 Autos 3.5............
Offline LS120
« Reply #6 on: November 15, 2010, 02:41:28 PM »
mine was a 3.5 then....
have someone looking at diff at the moment.. also have the drive shaft & 4 speed bedford gearbox & box member with re-modled gear stick, has the 202/186 bellhousing attached (has clutch,pressure plate, folk & bearing), also have a bedford front cross member setup for a 202/186.
also have  my old 2.3lt bedford motor in good order just needs a water pump.
also have a 2.3lt front cross member with good rubber isolators & locator plates.
have about 8 dash board plastic circuit boards in hand & also some petrol, water gauges, have speedo's in kmh but long arm broken( easy fix to glue something on to it ).
