  • Dot Guests: 275
Author Topic: Electrical Issue Maybe¿¿  (Read 8097 times)
Re: Electrical Issue Maybe¿¿
« Reply #10 on: November 07, 2010, 12:46:12 PM »
remember the 'ol girl has been sitting for 5 yrs?. :'(..........remove spark plugs before starting as this will make turning the motor over alot easier, check the oil isn't milky and or sludge, replace if so.you will need to get the oil back up to the top also to avoid any damage, remove rocker cover and poor a good cup over the rockers check for signs of moisture/rust on any parts.
Start with a fresh new or good battery, clean your earth's as well ,check your fuses, then just basically chase the battery leads and freashen the connections (loosen twist/clean tighten), now you know you have good power to the starter, and good oil /lubrication ,turn her over..... you can leave the rocker cover off just to see the oil "come up"then stop and replace rocker cover,spark plugs (new ones-cheap enough)....try again.
is there now fuel in the fuel filter? is it full of sludge/grit?  replace.
ok , do you have fuel pressure ? fuel at the carby? you might have to "prime" your fuel pump and carby, if so...
check your spark, then as mentioned you might have stale fuel in the carby/fuel pump,then that's another mission, not big but another mission....all part of learning/ beddiphilia. good luck!   it's a HUGE reward bringing the dead back to life......another one saved !
Dano
« Reply #11 on: November 07, 2010, 01:26:22 PM »
if all dano suggests fails ..........rip it out an chuck a chev in er  ;D ;D ;) ....remember if ya wanna REV ya run a chev !!!!!! ;D ;D :o
Offline tazinnz
« Reply #12 on: November 08, 2010, 05:04:10 PM »
even though i love chevs go with a holden v6 if you replace the 202 accually not a bad idea as they were a gas guzzler
IT aint over to the FAT lady sings and my sister isnt singing yet!!
Offline jimmyfreak
« Reply #13 on: November 08, 2010, 11:55:24 PM »
bens right it even if the battery does charge it won't hold charge..."borrow" a battery from another car....or if you don't want to spend too much buy a battery from the local wreckers...save moneys and all you have to do is get them to test it and make sure its a good one...they'll even throw in 3 month warranty usually...once you try a good battery if theres still nothing happening the battery may not be earthing properly....lol good old corrosion...best way to tell if a battery is not earthing properly...get someone to stand in front of the car...(obviously not while its in gear) if your headlights turn on instead of the car turning over battery is not earthing properly...if that is the case clean the terminals or replace the earth wire...or if your lazy like me get a jumper cable an attach from negative terminal to engine... otherwise everything dano said is good...
Offline KGG86
« Reply #14 on: November 11, 2010, 01:38:24 AM »
OK so ive checked the cables and cleaned from the battery to the starter motor , replaced the battery with a new one, went to start her she tried to kick over but then she just went dead and nothing again . .
Offline pickmeup
« Reply #15 on: November 11, 2010, 03:01:26 AM »
What Dano says is spot on.
Just one thing. If your earth wire to the van is in the usual place-move it.
I have found a couple times drilling a new hole for the earth wire solved some silly gremlins.
You can laugh but it worked 4 me.
Also you might want to look under the ignition switch and make sure there is no moisture or corrosion.
Oh and even if the battery is new, I still jump start the first time-just a thought.
-Charlie Hutton
Offline LS120
« Reply #16 on: November 11, 2010, 04:43:56 AM »
take your plugs out, take  the dizzy off & make sure its in nutral. see if you can turn it over by hand or a big socket & strong-arm.
it maybe tight or part seezed for sitting over the years...   ???
one old trick i know of is when you get itrunning turn it off, drain the old oil out & refill with desel fuel, start & let idle (dont rev..) for about 20-30 min.
Drain out & put on a new oil filter & oil.
man what a diff it makes to the motor sound & running. (from on old school drag racer)
 8)
« Reply #17 on: November 11, 2010, 09:34:56 AM »
Another thing to try is bang the starter while some one turns the key, the starter might be jaming.... good luck
