  • Dot Guests: 353
Author Topic: Looking for V6 commodore conversion kit  (Read 27241 times)
Offline Noid
  • Living the dream
Re: Looking for V6 commodore conversion kit
« Reply #20 on: November 23, 2010, 08:56:10 PM »
Don't forget you will need to modify the oil pick up and dipstick :)
« Reply #21 on: November 24, 2010, 09:10:29 AM »
The kit i got had a new sump and oil pick-up and tube in it, the old sump is on the shelf.
Offline KGG86
« Reply #22 on: November 25, 2010, 01:30:37 PM »
Is it true that An Engineer's Certificate is now required for all vehicle modifications. even if ur keeping the beddy a 6 ??
« Reply #23 on: November 25, 2010, 02:39:05 PM »
if it is 90% of west Australian beddies are in trouble.
« Reply #24 on: November 26, 2010, 07:13:49 PM »
someone was trying to tell me that i might technically need a cert because i replaced a 186 with a 202????
that is a joke! it takes the same engine mounts!!!
« Last Edit: November 26, 2010, 07:18:56 PM by able »
Offline tazinnz
« Reply #25 on: November 26, 2010, 08:27:52 PM »
most garages wouldnt know the difference if it jumped up and kicked them in the nuts
IT aint over to the FAT lady sings and my sister isnt singing yet!!
« Reply #26 on: November 26, 2010, 08:57:22 PM »
hey able using your "same engine mounts" theory we should be able to fit a big block chev then coz they use the same mounts  ;D ;D ;) the usual rule of thumb is more that 10%power increase needs engineer aproval   Cheers Neil
« Reply #27 on: November 26, 2010, 08:59:10 PM »
Hey Guys, i might be wrong, but the one thing you may need to do is have the new engine number put onto your paper work, if you ever get a check done by the cops at a roadside checkpoint, and the numbers dont match, it could be a long day trying to convince them that it is not stolen. My understanding is if you go to a v8 or make a structual change then you need and engineer to rubber stamp it.
Offline Banksx2
  • Willagee WA
« Reply #28 on: November 27, 2010, 09:19:12 AM »
That gives me a slight hassle coz the LWB 308 we bought has had the block decked and all I've got are nice clean machining marks where the engine number was stamped.
I've heard you can use x-ray to see the original numbers? Where the hell would I get THAT done  ???
Garry
« Reply #29 on: November 27, 2010, 09:41:44 AM »
Over here in Vic, we have to get a VP number from Vicroads if we don't have a engine or chassis number. The VP stands for Victorian Police. So you will have to chase your rego branch, or the police
