  • Dot Guests: 252
Author Topic: WRECKING MY SHORTY  (Read 14210 times)
Offline Grogan
Re: WRECKING MY SHORTY
« Reply #10 on: November 15, 2010, 12:10:32 PM »
I need a drivers side door latch assembly in good nick if anyone has one :)
Offline Marky
« Reply #11 on: January 24, 2011, 11:31:02 AM »
Still wrecking my shorty if any one needs anything pm....
dont wanna have to let it go to the crusher wiuth anything anyone needs
Beddy hwy diff with borg warner center..is for sale too..(new slave cylinders 6mths ago...)
PM me or 0421 965 049
Creative Media Producer
Offline cords
« Reply #12 on: February 03, 2011, 05:49:15 PM »
mate want the front guards willing to travel to get them if there any good
Cheers Gav
Offline wazzah
« Reply #13 on: February 04, 2011, 10:44:40 AM »
Hey buddy,
How much for the rear diff and front brake setup? Im in brissy and very interested,need to get my swb off drums :(
Pm with a price..cheers
wazzah
build it and they will come
Offline Marky
« Reply #14 on: February 06, 2011, 11:15:45 AM »
also...i have a custom made roof rack ...solid steel ...for sale
i have cut it in half and am using the back half on my CFL
heres some pics of the full size..
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=29308
n now the half size..
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=29367
Offline Marky
« Reply #15 on: February 06, 2011, 11:18:32 AM »
ive posted up some new oics of my latest build my new CFL.."CHINA WHITE"
PM me or call..not on net much ...this week...so calls are  best
Marky
Offline Marky
« Reply #16 on: March 16, 2011, 09:36:41 AM »
Great to meet some fellow bedford enthuisasts...
Been selling off bits n pieces over the last few weeks..
 met Craig from coffs ..restoring his Dad ol beddy..gonna be a nice machine
n Stan from eumumdi with a beast of a beddy camper
Clearing out the Shed n the yard so i
I have for sale
Hq disc brake set up for bedford..complete.and in working order..
I just pulled it off my daily driver
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=30224
2 x Set of front doors
1st set
Perfect working order
 matching & locking and winding windows.etc resprayed gloss black
with new door trims..
second set
 straight .but has lil rust..no locks windows etc
Roof Rack
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=30229
...Solid steel..Custom made for bedford..
Side Door..Glass for  windows front sides n rear..Bonnet Scoop.. custom fibreglass window frames inside
2 x grills
Black beddy is off to the crushers in a few weeks ...
call me if you need anything before the shell gets crushed
0421 965 049
« Last Edit: March 16, 2011, 10:15:20 AM by Marky »
Offline Marky
« Reply #17 on: March 16, 2011, 12:28:53 PM »
So just had a Buga of a week!!!
The Plan>>swap over donor front end. from my CFS to my CFL...estimated time...2 days  max..
Day 1... Undo from the donor front end CFS
undo..tie rod end..top ball joint..a lil smack with a mallet n hey presto she is undone!!
 unbolt lower control arms and top arms..sweet this was easy.. 8) 8)
CFL--repeat procedure on front end of China White...
hmmm top contrl arms are seized...bit of penetrol.. soaked..Beer time...
Day 2..those bolts should be loose by now....overnight soak..me thinks
 3 hrs later..still seized ..more penetrol...trying levering end of bolt no luck !!!
3 hrs later mallet in use n now much swearing n skin removed from elbows ,arms n knuckles n shins aaarrgghh!!!
BUGA!! swing a mallet in confined spaces
more penetrol...!!
Day 3
Day 3...
Starting to get a lil heavier now with the mallet...access is a problem..get a length of steel n start smashing the shit out the bolt from the front.!!!!!! 6 hrs later still no go...
Call local mobile welder to bring rong an oxy..we gonna heat this sucker up a lil she should just slide right out..Right!!?? wrong...after much melting ..smoke fire..n   untold swearing..
We had cut thru the top control arms ......n the bolts on both sides were seized beyond belief!! BUGA!!
I sat with my arms folded..Monster garage was on TV..images of setting my beddy on fire with a blow torch flashed thru my mind!!..just watched em set fire to a monster tractor..that didnt work..a smouldering beddy in the outer suburbs of brisbane could be on tv... sooon...aaarrrgghh
Better have a beer n think about what a mess i have made... 3 days ago i had a working van..
Now i have a useless piece of metal!!
There a knock at the door..its my mate.. a mechanic...”Sup Bro?”
  i tell him the situtation ...”ah easy man..just grab the crossmember off the donor van sweet as!”
when..lets grab a few beers n do it now..i look at the time..its 9pm..no worries..
we  jack up the engine...unbolt the steering.....
Now there are two bolts that either side that hold the crossmember to the chassis...these were as expected seized and rusted...Out  with the penetrol again....!!!v over night soak...end day 1am!!!
Day 4...
After a good soak..the bolts come looose...
Drop the crossmember out..n throw it on the lawn..cursing it aaarrrggghh!!!!!!
Clean up all the bolts on the wire wheel,,, soak the chassis holes n clean em up a bit
Change the engine mounts on the CFs..may as well ...they were shot
Un  bolt the donor front end from the cfs....give my self a hernia..dragin it up the side of the house..
Day 5
Bolt in donor front end...drop engine back on to crossmember..connect steering..
Bolt up new disc brakes ball joints etcs....nice its all together under there now...Beer time!
« Last Edit: March 16, 2011, 12:49:35 PM by Marky »
« Reply #18 on: March 16, 2011, 08:04:31 PM »
yeh they rust inside and seize..
ive never had it happen to a van of mine but ive herd of it happening.. and experienced it on someone elses van:(
ive herd of people bending the crossmember trying to get those rusted bolts out!
coulda happened to any of us marky!
« Reply #19 on: March 16, 2011, 11:30:06 PM »
top job Marky!!! good effort bro......glad you made it thru to the other side......HMMMM good name for a song , that one........ ;D :D
thanks for the laugh.
