  • Dot Guests: 317
Author Topic: I need a diff housing  (Read 13829 times)
Re: I need a diff housing
« Reply #20 on: October 06, 2010, 05:44:09 PM »
If you dont need the tank I wouldn't mind borrowing it to see what it looks like under the beddy.
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #21 on: October 10, 2010, 10:23:03 PM »
Shane should be taking the tank out in a couple of weeks, if you want a lend to check for fit . I'll let you know when it's out. Where's it going same as old tank or under the back.  Under the back was where I was thinking of putting it.
Julian
« Reply #22 on: October 11, 2010, 08:36:26 PM »
I'd be looking at fitting one in the factory position and one at the back. The first thing I want to do is look at the V6 tank roughly in position and then find out how much bigger the V8 tank is to see if it would fit ok.
« Reply #23 on: October 12, 2010, 08:37:50 AM »
Hey shane, when you are checking out the position of the tank for size, can you get some pics of the tank in position ? I will be doing my tanks soon, and was going to get some custom ones made up, but if a VN-VP tank will go in, i may consider useing my VP tank.
« Reply #24 on: October 12, 2010, 06:42:17 PM »
No worries mate.
Offline shaginwagin
« Reply #25 on: October 13, 2010, 10:32:47 PM »
Looks like I will have to get the tank out of the VN a lot sooner, I will have it out by this weekend Shane, work out how to get it to you.
Julian
Julian
« Reply #26 on: October 13, 2010, 10:42:02 PM »
Hi mate, I'm going away this weekend for 2 weeks. I'll happily pick it up for testing after that if it isn't used by then.
Thanks mate
Offline shaginwagin
« Reply #27 on: October 24, 2010, 11:12:30 PM »
Shane,  the fuel tank is out of the VN, its sitting on the garage floor, so just a call when you get back , i think you have my mobile number.
Julian
« Reply #28 on: October 25, 2010, 02:12:13 PM »
Thanks mate. I'll be back in town on Saturday so might give you a call on Sunday.
