  • Dot Guests: 218
Author Topic: Window regulator..  (Read 8620 times)
Offline erics8
Window regulator..
« on: September 12, 2010, 11:40:41 AM »
Hi all, was wondering how to fix a dodgy window regulator? im not sure if its the wound up spring by the winder or the roller channel nearer the door latch end that acts as the regulator?
Its not completely stuffed, only seems to let go from time to time, is there a way to refurbish it or do i need to go bedford hunting.. Cheers.. Even better would be a new passenger door if anyone knows where to find one in the waikato  :).. my ones seen better days, in the 90's  ::)
Re: Window regulator..
« Reply #1 on: September 12, 2010, 11:44:30 AM »
It's not the teeth on the arm is it? They get relatively worn after years of use. If it is I'm pretty sure they can be recovered by having the teeth rebuilt. You could possibly even flag the whole thing and try one of those universal power window conversions.
Offline erics8
« Reply #2 on: September 12, 2010, 11:53:46 AM »
hmm  not too sure ill tear it all to pieces and have a good look when it next stops raining..
the insides of doors are never a lot of fun
« Reply #3 on: September 12, 2010, 09:34:23 PM »
agreed:) i hate putting windows in and out and fiddling with regulators!
Offline Mark B
  • '79 CF SWB
    • Some of My Music
« Reply #4 on: September 13, 2010, 08:35:52 AM »
Rekon I spent a whole day putting drivers side window in and getting regulators etc. all working from scratch..Including figuring it all out etc. yukkkk
http://abakersdozen.com.au
« Reply #5 on: September 13, 2010, 08:43:40 AM »
did my drivers window, found it would have been a lot easier if I had have had 3 elbows per arm and go go gadget arms. you always drop something into the never never at the bottom of your door! ;D
Offline Mark B
  • '79 CF SWB
    • Some of My Music
« Reply #6 on: September 13, 2010, 08:47:27 AM »
yep, you need one of those flexible extendable magnet thingos when your doing beddy's ay?
« Reply #7 on: September 13, 2010, 04:33:50 PM »
I got a old speaker magnet on a piece of welding wire it works ok for retreving dropped things in doors & for finding screws & small things that I drop in the grass
« Reply #8 on: September 13, 2010, 04:51:04 PM »
i knew i have been holding onto the old speaker magnet for 2 years for somereason.. thanks reid:)
« Reply #9 on: September 13, 2010, 05:30:48 PM »
Your welcome there also good for holding 2 pieces off metal togeather for welding
