  • Dot Guests: 170
Author Topic: "JAG IT!"  (Read 31680 times)
Re: "JAG IT!"
« Reply #40 on: October 04, 2010, 10:39:32 PM »
Check these out from K&K crossmembers in Qld. You can order them to suit any track width(what's a Beddie?) they accept Jag components and come with a engineers certificate
Re: "JAG IT!"
« Reply #41 on: October 04, 2010, 10:44:58 PM »
The bare crossmember is $750.00 inc. postage and the coil over shocks are$650.00
Petrolhead
Re: "JAG IT!"
« Reply #42 on: October 04, 2010, 11:04:38 PM »
careful with those crossmembers guys they are set up parallel and as the jag is set up with sweeping arms (for anti dive /squat characteristics ) the third arms (at the stubs) are shorter and they will foul the lower control arms .the only solution is to fit steering stops limiting the turning circle (just the thing for beddies) I have invested over 350 hours in r&d on my Jag/Bedford f/ends and it has come down to manufacturing longer third arms which will be an expensive engineering nightmare    Cheers Neil
Re: "JAG IT!"
« Reply #43 on: October 05, 2010, 08:07:20 AM »
hey merlin dont you wish we were machines, so we could just charge battery while still working:) i do anyway.
Offline vanner065
  • It 's my fantasy
Re: "JAG IT!"
« Reply #44 on: October 27, 2010, 09:27:04 PM »
heres a pic of my Jag rear, still uses the original cage. It was the first Bedford in Australia to get the jag rear, was done in the late 1970's
DIAMOND VALLEY VANNERS
IF YOU DON'T TAKE IT OUT AND PLAY WITH IT, NO ONE WILL SEE IT !!
