  • Dot Guests: 317
Author Topic: Monsoon Shield  (Read 17184 times)
Re: Monsoon Shield
« Reply #30 on: September 10, 2010, 09:00:22 AM »
Yeah, I had these...
But now I have these. Much nicer...
Re: Monsoon Shield
« Reply #31 on: September 10, 2010, 09:02:18 AM »
Hey mezzmo, got  your van back yet. I hope your van does not disappear like the missing green van, lol  ;) if it does we can check skips pouch  ;D ;D  So are you going to remove the vinyl graffics,  i guess back to the body shop first.
This is what i had, like you rogue i am replacing, i am going to build my new mirrors from scratch.
« Last Edit: September 10, 2010, 09:07:27 AM by Bedfordcrazy »
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: Monsoon Shield
« Reply #32 on: September 10, 2010, 09:44:40 AM »
Oh yes, Rougue !! They are much nicer...Where bouts did u get 'em from?
http://abakersdozen.com.au
Re: Monsoon Shield
« Reply #33 on: September 10, 2010, 11:08:28 AM »
On ebay. There are heaps of them on there. They're aftermarket replacements for the Chev or Dodge (can't remember off the top of my head) vans and pickups. Once again there appear to be any number of manufacturers. I landed my ones from the states to my door in NZ for $110.00 NZD.
Re: Monsoon Shield
« Reply #34 on: September 10, 2010, 05:08:52 PM »
I got these ones because a mate has had the same ones on his van for 3 years with no problems, and they still look like new (the black ones that is) Sorry Rouge like this style better as it's on a van not a car reminds me of a jap mirror. MY THOUGHTS ONLY
Re: Monsoon Shield
« Reply #35 on: September 10, 2010, 07:04:09 PM »
Each to their own  ;)  I've had 4 different styles of mirrors now including the originals. Times change as do my tastes.
Re: Monsoon Shield
« Reply #36 on: September 10, 2010, 07:49:01 PM »
And your van only moves a couple of feet now and them, at this stage I'm not sure you even need mirrors  ;D As I grew up in the 80's and my job was all day around custom vans, the old style mirrors is what I got used too. Hard to change.
Offline cfjeff
Re: Monsoon Shield
« Reply #37 on: September 10, 2010, 09:12:23 PM »
Baz they are the the same ones I put on my van 4 years ago (the black head ones, I had them painted to match), I used to have west coasters before that but found they had a rather large blind spot. When you go to mount them i found they sat on an angle and looked a bit odd so I cut the bottom aluminum bar and redrilled it now they sit level which looks better. Just a suggestion if you want it to look better as a front profile.
Cheers Jeff
Just customize it!
Offline gazza
Re: Monsoon Shield
« Reply #38 on: September 11, 2010, 12:11:53 AM »
g,day is that a tilt front on the van as i cant see the bonnet opening line looks good
gsph
Re: Monsoon Shield
« Reply #39 on: September 11, 2010, 05:43:03 AM »
Can't argue with that  ;D I started off with the originals and then went to a set of stainless steel truck mirrors. They were a great set and really looked the part. Then I wrote the van off and decided to take the opportunity to remodel the front. The truck style mirrors didn't really suit anymore so went to the style you now have. That was about 12-15 years ago. When I finally decided to do something about the lump of metal sitting in the garage I thought I'd try for a more sporty look. Was trying some of the smaller mirror sets but they just didn't cover enough of the rear so that's when I decided on the Chevy mirrors. Not as obtrusive as the larger mirrors but still a good viewing area and I really like the style.
Hi. No, there's actually no bonnet. I've got a mid-mounted engine so at the time we decided that we could get away without one. I've now decided that that probably wasn't such a good idea so I have some plans to rectify that.
