  • Dot Guests: 264
Author Topic: CF cab chassis  (Read 5065 times)
Offline mr c
CF cab chassis
« on: August 18, 2008, 08:09:16 PM »
ok guy need sum info can the cab be removed from the chassis on a cab chassis cf ?
cheers tony
Offline Jock
Re: CF cab chassis
« Reply #1 on: August 18, 2008, 09:49:36 PM »
Tony,
I'm not sure. You would think that you would be able to.
From these pics I have you can't really tell...
Will ask someone and get back to you with an answer.
Jd
Re: CF cab chassis
« Reply #2 on: August 18, 2008, 09:55:07 PM »
in short ..........no
Offline Jock
Re: CF cab chassis
« Reply #3 on: August 18, 2008, 10:10:23 PM »
Craig,
How are you mate?
Are you able to elaborate on why you can't remove the cab?
Jock
Re: CF cab chassis
« Reply #4 on: August 18, 2008, 11:10:16 PM »
You can remove the cab from the chassis, but it wont be much good when you finish. The cab and chassis are assembled and welded together fairly well
Offline mr c
Re: CF cab chassis
« Reply #5 on: August 19, 2008, 10:05:26 AM »
oh well there goes that idea no biggie still work sumthing out just thought if it could be  unbolted that it would be easier to paint and work on
Re: CF cab chassis
« Reply #6 on: August 19, 2008, 11:44:34 AM »
you cant separate them like other tuck cabs but you can still mod them theres 1 in merlin's shed with extended cab and v8
