  • Dot Guests: 322
Author Topic: Bedford Fuel Tanks.  (Read 13603 times)
Bedford Fuel Tanks.
« on: August 12, 2010, 02:29:45 PM »
Hi all, I have a Q.  Does anyone know what the fuel tank size is for a swb van. I am putting duel tanks into my van, mainly as a saftey thing. I am wondering can we cut the tank [qualified tank guy] and make it larger to carry more fuel ? Any advice appreciated.
Re: Bedford Fuel Tanks.
« Reply #1 on: August 12, 2010, 04:10:26 PM »
if you want to cut or weld a petrol tank you MUST fill it with water otherwise it'll go bang.
I haven't filled my tank up for a while, but i think it's about 50L
Your easiest option would be to make up a custom tank, it'll look nicer than a butchered tank. Then you can pick where you want your fuel gauge, whether you want to use a boating grade gauge, or a gauge from the wreckers etc....
Just need to figure out your dimensions and then weld up some sheeting into a box
« Reply #2 on: August 12, 2010, 04:28:23 PM »
Seeing as you are in Brisbane I am screwing myself over by telling you this. F100 rear fuel tanks fit nicely under Bedfords and they are about 75L.
« Reply #3 on: August 12, 2010, 07:15:56 PM »
VN commodore tanks fit well too, they come in 60 and 80 L (I have 60 under my standard van)
« Reply #4 on: August 12, 2010, 08:02:21 PM »
I didn't know that. Thanks
« Reply #5 on: August 12, 2010, 08:08:29 PM »
Busy, do you have a picture of the VN tank? Does the VN tank have an internal pump?
« Reply #6 on: August 12, 2010, 08:17:40 PM »
Will the VN tank fit where the original beddie tank is or do you put them op the back
« Reply #7 on: August 12, 2010, 08:30:04 PM »
The F100 fits where the original is. If that helps
« Reply #8 on: August 12, 2010, 08:47:38 PM »
Yes thanks Shane my tank had rust holes in the bottom & I soldered them up but I'm not happy with that they will probably come through again at the worst possable time I'd rather replace it now So now to find a f100 tank Thanks again Cheers Reid
« Reply #9 on: August 13, 2010, 12:42:36 AM »
Anyone come up with any good ideas for the rubber breather that joins the filler to the tank? the one that splits and fills the van with fumes....
