  • Dot Guests: 325
Author Topic: Rogue Trooper  (Read 185289 times)
Re: Rogue Trooper
« Reply #10 on: August 19, 2008, 01:49:24 PM »
What car is that dash out of? Jd
The dash is out of a VK commodore. I split it in the middle to extend it. I have done away with it since these photos were taken and am building my own. Just need to finish mounting the heater unit and blower and I can then start putting together the frame.
Offline Jock
Re: Rogue Trooper
« Reply #11 on: August 19, 2008, 10:44:21 PM »
How hard was it to wire in the vk dash?
Re: Rogue Trooper
« Reply #12 on: August 20, 2008, 06:04:10 AM »
I did it as part of a complete rewire. How easy does that sound?  ;)
Have completely stripped the wiring again so once I get the dash sorted out and the new donk in place it'll be complete rewire mk2!  8)
Offline Jock
Re: Rogue Trooper
« Reply #13 on: August 20, 2008, 05:34:36 PM »
There's nothing like ripping it all out and starting again now is there... I admire your method! :D hahahaha
Auda
Re: Rogue Trooper
« Reply #14 on: August 27, 2008, 03:30:00 PM »
Rogue Trooper, do you have any photos that show your engine mounts ? I'm thinking about mid mounting a LD28 diesel.
Auda
Re: Rogue Trooper
« Reply #15 on: August 28, 2008, 01:52:19 AM »
tried to post a mid mount photo for you but wouldn't upload ....upooad folder too big...it was 19kb ???
Auda
Re: Rogue Trooper
« Reply #16 on: August 28, 2008, 05:22:56 AM »
You could email it to me bruce_mc_a@hotmail.com
Thanks
Auda
Re: Rogue Trooper
« Reply #17 on: August 28, 2008, 12:47:41 PM »
Auda
I'll put something together. The engine crossmember is out at the moment seeing as I have removed the engine so that makes it easy to take some photos. Might be a day or 2 as I'm pretty flat tack at the mo'.
Re: Rogue Trooper
« Reply #18 on: September 02, 2008, 01:11:37 PM »
Here's a pic of my engine crossmember taken from the front. It bolts up to the old gearbox crossmember mounts.
Re: Rogue Trooper
« Reply #19 on: September 02, 2008, 05:32:55 PM »
did you make that up rouge trooper?? is that just tubing yeh? looks great.
have you got it engineered?
