  • Dot Guests: 270
Author Topic: Clutch cable  (Read 4180 times)
cf truck
Clutch cable
« on: August 10, 2010, 11:52:15 AM »
Gday, I have just broken my clutch cable on my CF tray top truck it has a 5 speed supra g/box, where do I purchase a cable from, Ive googled it and havent found one yet!
Thanks Neil.
cf truck
Re: Clutch cable
« Reply #1 on: August 10, 2010, 08:50:52 PM »
Come on you blokes someone must have replaced their clutch cable, I m sure its a standard cable but where do you get them from?
Neil.
Offline grandad
Re: Clutch cable
« Reply #2 on: August 10, 2010, 08:54:43 PM »
sorry both my vans have been autos
Re: Clutch cable
« Reply #3 on: August 10, 2010, 09:06:46 PM »
type in "supra clutch cable" without the talking marks into the search box above your first post.
anything that mentions those three words will pop up. then just click on the thread titles above each snippet and it will take you to all the previous threads where "supra clutch cables" have been mentioned.
right clicking on the thread titles and opening them in new tabs makes it faster as the original search remains intact and you do not have to repeat the search again..... just work down the mentions.
« Last Edit: August 10, 2010, 09:11:12 PM by able »
Re: Clutch cable
« Reply #4 on: August 10, 2010, 09:23:06 PM »
from a quick scan the cables are Frankenstein... alot of people have problems with them snapping and a hydraulic clutch seems to be the answer... or put in a new cable one and put up with the continued snapping...
Re: Clutch cable
« Reply #5 on: August 11, 2010, 12:21:54 AM »
Do the search
And I will say again - if you get to the problem of the braking cable - and fix it you wont have problems in the future.
Its quite a while since I fixed mine (like 4 or 5 years) and I think it was CJ trucks in Bayswater (there is a thread on them here somewhere) that got it for me, but look for cable makers in your area because they should be able to do it for you as well.
My isses were
Cracked firewall with a bodge fix - I welded the cracks and a thick washer for reinforcing - no more problems.
Worn and incorrectly adjusted clutch fork - built up the pins on the clutch fork and correctly adjusted it.
No more problems
cf truck
Re: Clutch cable
« Reply #6 on: August 11, 2010, 08:46:25 AM »
Gday, I havent had any problems with the cable before this I ve owned the truck for 6 yrs and 90,000km , the firewall is already reinforced, I just need a new cable!
Thanks Neil.
Offline Ian
  • 76 CF, 350, Jag Rear
Re: Clutch cable
« Reply #7 on: August 11, 2010, 10:49:03 AM »
I use Flexable Drive. 37 Adrian St. Welshpool WA 6106, (08) 9362 1544
they made up an extra Length Turbo 400 shifter Cable for me, excellant quality too, they also sell & calibrate instument gauges (SW)    Ian
Re: Clutch cable
« Reply #8 on: August 11, 2010, 02:39:44 PM »
Hey Neil pm Craig "obsession" i just fitted an auto in his truck and his cable is just lying on the floor    Cheers Neil
