  • Dot Guests: 203
Author Topic: Tie rod Q  (Read 5855 times)
Offline Sweet Shock
Tie rod Q
« on: July 09, 2010, 08:03:13 PM »
I have a question, When doing a left turn my tierod rubs the edge of the rim, can this be ajusted, I have 7’ rims with about 100mm backspace, or will I have to put 6’ rims on, This is for my cert thanking you pete
Offline outriding
Re: Tie rod Q
« Reply #1 on: July 09, 2010, 09:40:14 PM »
I was looking at your van in the gallery wondering what size tires you have,  ???
Offline Jeff
Re: Tie rod Q
« Reply #2 on: July 09, 2010, 10:56:39 PM »
Would a thin spacer behind the wheel help?
Funny old life.
Re: Tie rod Q
« Reply #3 on: July 10, 2010, 11:21:35 AM »
By wrights, the tie rod should stay the same distance of the rim, unless it is starting to wear and it twist when turning the wheel. check for slop and easy movement.
                             Rossie
Offline Sweet Shock
Re: Tie rod Q
« Reply #4 on: July 10, 2010, 02:00:21 PM »
Sorry my mistake, Its the brake hitting the lower wish bone, anybody no how I can fix this thanx Also I have 8" on the back and I cant take any short cuts because Im doin this for a engine cert   pete
Re: Tie rod Q
« Reply #5 on: July 10, 2010, 02:07:49 PM »
In that case I would say you have an HQ disc conversion and it's the caliper hitting the small tab that sits out from the wishbone. You can grind that tab off if that's what's causing the issue. Just smear some grease over the ground bit when you've finished to get rid of the shiny bits and no-one will ever know.
Offline Worzel
Re: Tie rod Q
« Reply #6 on: July 10, 2010, 05:11:32 PM »
from the CRS instruction sheet
"Note: On the rear outer ends of the bottom wishbones, remove the steel protrusion as
under some conditions this could hit caliper."
Re: Tie rod Q
« Reply #7 on: July 10, 2010, 06:49:20 PM »
Rogue, is right if you have discs, just read this in a copy of CVT you have to do this if you use a Disc kit.
Offline Sweet Shock
Re: Tie rod Q
« Reply #8 on: July 10, 2010, 07:02:47 PM »
I
Offline Sweet Shock
Re: Tie rod Q
« Reply #9 on: July 10, 2010, 07:19:38 PM »
I see, That makes sence, Thanx heaps, And Im trying to post a pic
