  • Dot Guests: 362
Author Topic: body removal  (Read 7331 times)
Offline mbasinski
body removal
« on: June 25, 2010, 05:30:13 PM »
is it possible 2 take the body clean of the chassis.
is it just held down by bolts or is it welded or both
Re: body removal
« Reply #1 on: June 25, 2010, 06:22:47 PM »
Bedford vans have a monocoque type construction so that the body forms part of the chassis. So no you cant remove the body.
Offline mbasinski
Re: body removal
« Reply #2 on: June 25, 2010, 10:07:05 PM »
was i dreaming or did i see a photo with the body hinged up so the engine could get dropped in> somewhere on the site
Re: body removal
« Reply #3 on: June 25, 2010, 10:47:19 PM »
Eddy and I lifted the whole van up off the front end/motor/gearbox - its the easiest way to do an engine swap.
Here using an engine hoist
And here using a gantry, block and tackle
« Last Edit: June 25, 2010, 10:53:30 PM by Warren »
Re: body removal
« Reply #4 on: June 26, 2010, 02:39:52 PM »
gantry system is less hastle thou.. you can roll the front end out without having to put the van on stands way up in the air (usually quite scary on a windy day)
Offline gazza
Re: body removal
« Reply #5 on: September 20, 2010, 06:13:21 PM »
g,day guy,s has anyone put a van body on a cab chassie ive noticed my lwb truck is 330 mm longer than my lwb van good start for a long van especially with shorty low roofs on top has any one done it yet? chears
gsph
Re: body removal
« Reply #6 on: September 20, 2010, 10:24:50 PM »
Gazza
I would think that starting with a cab/chassis, extending the chassis and mounting a couple of bodie sections on it would be easier than stretching a long wheel base.
Not sure how this one was done but looks good.
Offline gazza
Re: body removal
« Reply #7 on: September 25, 2010, 12:42:20 PM »
ooyea! thats nice, you got any more pics mate hr\ard to find in standart trim mis it aussie van?
gsph
Re: body removal
« Reply #8 on: September 25, 2010, 05:47:29 PM »
Gazza
I dont have any more pics, I found a couple of pictures of it on a NZ hot rod site I think.
Maybe one of our Kiwi bretheren  might have more info.
Re: body removal
« Reply #9 on: September 25, 2010, 06:37:53 PM »
I think I have a couple of pictures of it but wont be home until tuesday
from memory its running a 400 chev which is mounted in the front of the second section, which is the normal length for a jumbo from the rear wheels. It's also dark brown
