  • Dot Guests: 292
Author Topic: installing a trimatic - step by step  (Read 18294 times)
Offline JOE RYAN
Re: installing a trimatic - step by step
« Reply #40 on: July 18, 2010, 09:08:16 PM »
Worby876
I had the same trouble with the linkages always jamming, after removing and reshimming the same problem returned shortly afterwards in the end I put in a trimatic auto and all good now
Joe
« Reply #41 on: July 18, 2010, 09:18:36 PM »
Ian I think you'r gona need a V8 & auto to move that mother + tow a boat the old 202 is a good motor but not that good not enough torque cheers Reid
« Reply #42 on: July 19, 2010, 07:05:39 PM »
I think Restoreid is right, the 202 is a great motor, but well under powered for your camper, check my Gallery, I have a camper with a 202 fully worked 3 speed trimatic with overdrive and a 3.5 ratio rear end, have changed it to a 4.1 good low down power and good top end with the overdrive, but the problem the motor has to work hard and this is something you don't want on a relaxing road trip. I am changing to the VN Holden 3.8 v6, no more power problems and drives with ease, sometimes it better to make new than try and fix old. My thoughts anyway.
