  • Dot Guests: 382
Author Topic: beddydore  (Read 78012 times)
beddydore
« on: May 26, 2010, 06:54:20 PM »
Ok I have followed the lead and brought myself a VN Calias holden commodore with the V6 ...
Am going to put the running gear (and maybe dash) in my standard CF
So instead of a BedFORD, I guess it's a beddydore  ;D  :D
Offline cfjeff
Re: beddydore
« Reply #1 on: May 26, 2010, 07:12:41 PM »
or perhaps a commbed, or a bedhol, maybe bedden.
cheers Jeff
Just customize it!
Re: beddydore
« Reply #2 on: May 26, 2010, 07:34:46 PM »
Damn, I better get my butt into gear then. Be a bit embarrassing if yours is going before mine.  :D
Re: beddydore
« Reply #3 on: May 26, 2010, 07:47:39 PM »
David, welcome to check out my van if needed, also runs the dush from the VN, will be off to my mates soon, swapping the running gear into the camper, and the worked 202 into the Jumbo. etc etc etc etc, should be a straight swap,,,,yea right!!!!!!!!!!!
Re: beddydore
« Reply #4 on: May 27, 2010, 07:48:20 AM »
hey busy, has your calais got the digital dash in it, i know the vk calais came out with the digital.
Re: beddydore
« Reply #5 on: May 27, 2010, 08:44:03 AM »
yeah George it has the digital dash, has cruise control, fuel used and fuel remaining and other stuff
[edit] oops, the speedo, rev counter, fuel etc aren't, the other stuff is
« Last Edit: May 27, 2010, 05:54:31 PM by BusyKiwi »
Re: beddydore
« Reply #6 on: May 27, 2010, 08:46:13 AM »
Rogue, don't worry, this is the standard van, not my custom one. I need the standard van as a daily driver as I have to many vehicles here - 2 vans, car and motorbike, need to get rid of the car
means time off the custom van but will hopefully give me a decent daily driver
Re: beddydore
« Reply #7 on: May 27, 2010, 08:50:36 AM »
Busy have you done any more to the custom van of late?
Re: beddydore
« Reply #8 on: May 27, 2010, 08:56:39 AM »
hey busy, good to see you have your priorities right mate, loose the car and have the van as the daily driver. YES lol  ;D ;D
Re: beddydore
« Reply #9 on: May 27, 2010, 10:20:54 AM »
Actually I was just meaning getting the V6 up and running as mine hasn't really moved since I put it in after Xmas although I'm held up a bit with a lack of cash to get the diff in. I need to recondition the brake calipers (already have the new discs and pads), buy the power steering rack (as that is being fitted at the same time as the diff) and then I can get the diff sorted. After that I will be working on getting the motor into some sort of conditon for starting. Still, on the positive side it does give me more time to spend on sorting out the interior.
Bit of time off the custom will probably do you good anyway. Gives the brain time to recharge.
« Last Edit: May 27, 2010, 10:22:45 AM by Rogue Trooper »
