  • Dot Guests: 86
Author Topic: beddydore  (Read 22048 times)
Re: beddydore
« Reply #20 on: May 28, 2010, 10:36:35 AM »
You're welcome. It's a bit of a sh1t because the bottom of the timing cover also seals against the front section of the sump so you need to be really careful pulling the cover off so as to not munt the sump gasket othewise you might have to replace the sump gasket as well to avoid oil leak city. Other than that it's a complete doddle to replace when the motor is out. It didn't matter to me as I was swapping my sump anyway.
Lots of good stuff here on the V6 Buick motors...
http://forums.justcommodores.com.au/vn-vp-holden-commodore-1988-1993/
Re: beddydore
« Reply #21 on: May 28, 2010, 01:42:46 PM »
Cheers Rouge, just took it for a long drive, gee these motors are just right for the Beddie, Mine is more of a rattle as I paid more attenion this tiime, so may be somthing different as the motor is a tight fit Its a bit hard, wiil give the motor a good going over once its out. Cheers
Re: beddydore
« Reply #22 on: May 28, 2010, 07:04:18 PM »
Thanks Rogue.
Hey Bas, you going to be home next week, am keen to come look at your set up. I'm not going to run power steering or air con
Re: beddydore
« Reply #23 on: May 29, 2010, 06:36:07 PM »
No Probs David, will PM my numbers so you can contact me first if required, theres a few things I would change, but the setup fitting is all ok, the motor sits forward and the sump has not been changed, so sits above the cross member, but still seems to sit quite low in the van. Bas
« Last Edit: May 29, 2010, 06:38:37 PM by Bas NZ »
Re: beddydore
« Reply #24 on: June 30, 2010, 07:07:36 PM »
conversion is going well.
Because the fuel injected motor I had to either modify the bedford petrol tank or just use the commodore one, I choose the latter. just brought 90 degree pipe (2in) and got the radiator place to put in a new filler pipe. Took the hooks off the bedford straps and welded on the commodore straps, other end just made some brackets for the threaded bedford hooks. the commodore has built in pump and suits the fancy stuff on dash so all should be good.
Am converting the diff, using commodore centre with bedford axles and housing. The weird thing is the diff I had in there was a cresta (pinon at least) at 3.7.1 gears so could of been a bitsa.
Bas, I did have to cut the floor back to the gearstick hole, yours is way forward because of the power steering. was still good to see though.
The exhaust I used two cobies and ended in front of the rear wheel, hopefully will be quiet enough.
Still got a bit to do but getting there.
i got the old 3.3, trimatic and aussie assembled front beam with engine cover to suit on tardeme if anyone is keen
Re: beddydore
« Reply #25 on: June 30, 2010, 07:21:50 PM »
David, who is doing the diff ? will slot engine holes in the mounts and move motor back alittle to clear the gap from the fan when I do the change over.
Re: beddydore
« Reply #26 on: July 01, 2010, 07:41:25 AM »
McQuoid engineering is doing the diff, i think it was $750 he charges for the conversion
Re: beddydore
« Reply #27 on: July 01, 2010, 08:51:12 AM »
thats sounds like a pretty darn good price busy
Re: beddydore
« Reply #28 on: July 01, 2010, 01:24:19 PM »
David, next time you are around there, can you ask him if he can work on Dual Wheel diffs, Thanks Bas
Re: beddydore
« Reply #29 on: July 01, 2010, 06:26:07 PM »
there should be no reason why he couldnt..
