  • Dot Guests: 292
Author Topic: beddydore  (Read 22052 times)
Re: beddydore
« Reply #10 on: May 27, 2010, 12:26:38 PM »
hey rogue, what are you doing about your tailshaft, I need to look at mine in the next week or two, what does it cost to redo to the new length.
Re: beddydore
« Reply #11 on: May 27, 2010, 01:12:58 PM »
not cheap george
Re: beddydore
« Reply #12 on: May 27, 2010, 05:05:36 PM »
thanks benny, that cheered me up. lol  ;D  sometime between now and the end of this build, i am going to find a custom mod that is cheap and easy. So far i have'nt found that. lol  ;D :o
the joys of beddyfying.
Re: beddydore
« Reply #13 on: May 27, 2010, 05:10:58 PM »
Those little clip on air fresheners aren't too dear.
Re: beddydore
« Reply #14 on: May 27, 2010, 05:57:29 PM »
Rossie, I have but nothing you'd see in photos, just a bit of body work.
My girlfriend lives 1.5 hours away and i go see her every second weekend, and sundays I am here i take the motorbike for a scream - but I will
Re: beddydore
« Reply #15 on: May 27, 2010, 06:00:08 PM »
I think it's about $180 to get drive shaft done
Don't worry Rogue, I'll get the standard van running but may have to strip the engine down, has a bit of a tap going on (could just be tappets) but if the cash is there might give it a birthday
Re: beddydore
« Reply #16 on: May 27, 2010, 07:16:02 PM »
Mine has a tap going on too, but when you put the foot down it goes. ?
Re: beddydore
« Reply #17 on: May 27, 2010, 07:30:04 PM »
mate over here got charged 300 for tailshaft mod!!
Re: beddydore
« Reply #18 on: May 28, 2010, 06:02:08 AM »
If you have a tapping then it is probably more than likely the the timing chain tensioner has destroyed itself. The VN engines were notorious for it. I replaced mine while the engine was out of the car. Use a later model one as they were of much better construction.
Actually 'replace' is probably the wrong word to use. It was just no longer there. Found the remnants in the sump while I was replacing it which is how I found out what the tapping was.
« Last Edit: May 28, 2010, 06:14:56 AM by Rogue Trooper »
Re: beddydore
« Reply #19 on: May 28, 2010, 10:14:26 AM »
Hay thanks Rouge, yea having trouble to find out where its comming from, shounds like top / front of motor, it's not there all the time, idel is ok, bit of a rev it comes and goes while you drive though the gears, when I pull it out, well wheel it out will have my mate / greace monkey have a look at it. Bas
