  • Dot Guests: 248
Author Topic: need advice on dent  (Read 10339 times)
Bren
Re: need advice on dent
« Reply #10 on: August 19, 2008, 02:53:00 PM »
or you could do what im doing at the moment, paint the whole car the flattest black you can mix up... and watch the dents just dissapear  :D
« Reply #11 on: August 19, 2008, 07:12:11 PM »
flat black is the best..
i rolled undercoated bits about 3 or 4 months ago on my black beast.. it was massive patchy back then.. now its not so bad. i make sure theres a bit of dirt on there all the time and everyone says good paint job!!
Offline strez
« Reply #12 on: August 26, 2008, 04:05:23 PM »
there only one thing better than flat black and thats what i`ve got covers dents rust stains and even where the bog falls out  ;D
« Reply #13 on: August 26, 2008, 07:50:29 PM »
yeh what is it strez?
is it cheap? cause Cheap = Good!!
Offline strez
« Reply #14 on: August 26, 2008, 08:08:28 PM »
it`s the rock effect
painted over black acrylic spray/splatter white , splatter black , airbrush black lines , highlight with white airbrushing will cover every thing from stone chips to bird sh*t and dents . dents what dents? ;D
Offline Jock
« Reply #15 on: August 26, 2008, 09:58:07 PM »
Strez,
How many hours went into your paint job? Do you add to/change it regularly?
I like the wolf on the side...
If you were to pay someone to do what you've done how much would you be up for?
Jd
Tweaker
« Reply #16 on: August 26, 2008, 10:01:13 PM »
Strez,
Jd
Would be cheaper to remove the dents I would think!  :o  ;)
Bren
« Reply #17 on: August 27, 2008, 12:07:02 PM »
but it looks alot cooler like that anyway.
Offline strez
« Reply #18 on: August 27, 2008, 04:54:43 PM »
it`s a bodgy job !! van was only suposed to last 6 months 3 years later i still driving it . took 4.5 hours to do whole paint job including wolves .  just did it in acrylic and wasn`t made to last although its easy to touch up and i`ve been thinking of painting the grill area and the roof repairs as looks like it might be awhile befor i get back into it (too many other things on my plate) .
Offline strez
« Reply #19 on: August 27, 2008, 05:05:04 PM »
heres some photos of the inside although has a woodden steering wheel now
