  • Dot Guests: 299
Author Topic: tie rod ends  (Read 15683 times)
Re: tie rod ends
« Reply #10 on: May 20, 2010, 07:40:48 PM »
hey busy i take it u noticed the similarity to my first post here an your last post in the f/b debate thread  ;D  ;D yeah corse u musta  ;)
Re: tie rod ends
« Reply #11 on: December 03, 2010, 04:41:48 PM »
where are we getting these , these days? tie rod ends . that is....how much?
Offline Sweet Shock
Re: tie rod ends
« Reply #12 on: December 03, 2010, 09:05:50 PM »
Im getting mine from good old England $80 for 2 including post, Takes a month to get here thow, I priced them $72 each at repco
Re: tie rod ends
« Reply #13 on: December 04, 2010, 12:23:55 AM »
was this a supplier SS or a lucky ebay strike?
Offline Sweet Shock
Re: tie rod ends
« Reply #14 on: December 04, 2010, 09:50:56 AM »
I guess a supplier He has 10, If you go to uk ebay and type  (tie track end), youll  find it 12 pound + 12 pound postage at this moment, I always check they world wide post
Offline Sweet Shock
Re: tie rod ends
« Reply #15 on: December 04, 2010, 09:53:51 AM »
Forgot to say tie track end cf
Re: tie rod ends
« Reply #16 on: December 04, 2010, 03:00:27 PM »
cheers Big fella. 8)
Re: tie rod ends
« Reply #17 on: April 07, 2011, 12:10:24 AM »
cool ,got new tie rod ends....(cheers again) have had a little crack at them but in between jobs,(every thing cracked but still tight in sleave) gave them a good soaking , any tips, pointers b4 i give them full noise?
Offline Hippo
  • 1977 CF LWB Motorhome
Re: tie rod ends
« Reply #18 on: April 07, 2011, 08:02:00 AM »
Undo the nut but leave it on the tie rod end, grab a big hammer and give the arm it
is bolted into a solid hit on the end that faces towards the rear of the van, and the tie rod
end will pop up.
What happens is when you hit the arm it compresses slightly and because it is a taper
it pops the tie rod end out.
Dennis
Offline Sweet Shock
Re: tie rod ends
« Reply #19 on: April 07, 2011, 08:42:02 PM »
I tried that but ended up buying a puller for $80, The fork stuffed up and pullers from super cheap broke, Ive used the puller 4 times now but it saved me the frustration Its only bout 5 inches long but did the job easy
