  • Dot Guests: 336
Author Topic: Tierod adjusting  (Read 3379 times)
Offline Sweet Shock
Tierod adjusting
« on: May 19, 2010, 09:48:09 AM »
I need to adjust my left tierod, Is it as simple as hitting it off and turning it a couple threads and will it need a wheel alignment or something. Thanking you     pete
Re: Tierod adjusting
« Reply #1 on: May 19, 2010, 10:24:01 AM »
Hi Pete....If you have a close look at the tierod you will see that at the end of it there is a big nut. And also  the steeting arm itself will have 2 flat sides on it which you can put a big spanner or shifter on. Once you loosen the big nut, just turn the steering arm until you get the setting you desire. Most wheel aligment shops can do this. ;D
« Reply #2 on: May 19, 2010, 11:11:06 AM »
hey pete, you can trust johns advice, he is always adjusting his big nuts. ooooppps. lol  ;D
Offline Sweet Shock
« Reply #3 on: May 19, 2010, 12:41:46 PM »
Thanx for the quik reply john, I see what you mean   pete
« Reply #4 on: May 19, 2010, 03:52:38 PM »
Yeah i must buy the right sized undies soon ;D
« Reply #5 on: August 10, 2010, 11:20:40 AM »
first van i ever had i stacked (pretty bad roof tooked like a tee pee) . i was detirmined to fix it but could work out how to adjust tie rod ends and that got me that annoyedf i gave up and sent it to the crushed after that:(
« Reply #6 on: August 10, 2010, 06:14:46 PM »
hey johnno. . . they will   :o hang out either side n  :'( bruise th inside of yor knees if u go th right size ones  ;D  ;D
