  • Dot Guests: 184
Author Topic: power steering kit  (Read 10585 times)
Re: power steering kit
« Reply #10 on: May 10, 2010, 08:22:36 PM »
gee i wish i thought of using a bevel box on my van ::) ;)
« Reply #11 on: May 10, 2010, 10:55:29 PM »
Is the rack it self actually lengthened? Or just the rods?
Shane if you look closely you can see the extender/converter - it has a male thead on one end and a female on the other.
Male end goes into the bedford tie rod end, and the femal end goes onto the rack.
so I would say that NO the wrack has not been lengthend.
« Reply #12 on: May 11, 2010, 12:34:24 AM »
If the rack hasn't been lengthened she gonna suffer chronic bump steer .I fitted up a VY rack to my f/end and had to lengthen it by some 70 odd mm and off set it to the right to get the turn circle central i would think a VN rack would be similar in length                       Cheers Neil
« Reply #13 on: May 11, 2010, 06:49:07 PM »
Warren is right, the main rack is standard, and sorry guys no bump steer, it works just fine, as I said before the Transit is a good swap but this works just as well, I guess not knowing much about this kind of set up but would think the transfer / bevel box has a lot to do with the out come, but on full lock there is about a inch before the wheel hits, so I guess the lock is as good as your are going to get.  Also look where the rack is mounted, its out in the front not close to the beam, the tierods also go up not down as standard, with the rack mounted so far foward it must help. Bas
« Last Edit: May 11, 2010, 06:53:24 PM by Bas NZ »
« Reply #14 on: May 11, 2010, 07:44:25 PM »
Hey Neil ...Fix that bloody engine mount yet??? ;D ;D
« Reply #15 on: May 11, 2010, 11:24:47 PM »
Hey Johnno not yet these things take time and planning ya know  ;D ;D you fixed ya accelorator yet seemed stuck on half throttle on the run lol ;D ;D ;)
« Reply #16 on: May 12, 2010, 09:28:20 AM »
HaHa ;D :D ;D Ya cheeky bugga :D :D  I was lucky that i could hold my big 173 back.!! Woohoo :o
« Reply #17 on: May 12, 2010, 10:02:05 AM »
johno wack a sniffer kit on the old girl shell go out with a bang! Or better yet did you see the new supercharger kits in aust street rodder this month?
