  • Dot Guests: 34
Author Topic: axel question  (Read 9535 times)
Re: axel question
« Reply #10 on: May 06, 2010, 09:11:39 PM »
what about this on john??
B/W VK6 & VL N/A 6-cyl- 25 spline..
ive herd a rumor that there is a side gear that fits both and if its gunna be one it would be this one i think
might visit the wreckers tommorow to make sure.
even if its not broaching is not expensive.
Re: axel question
« Reply #11 on: May 06, 2010, 10:00:02 PM »
just rip into it with an angle grinder ben,
 and weld it .
make sure ur wearin a suit of armour though.
« Last Edit: May 06, 2010, 10:01:38 PM by marty »
Re: axel question
« Reply #12 on: May 06, 2010, 10:46:40 PM »
Diff splines and diff information
This was posted on another forum a while back about borg warner diffs.
FORD
xd falcon/6 cyl/25 spline/2 pinion/thin axles
xd falcon/5.8/4 pinion,28 spline/2.92 ratio and 2.75.
xe falcon/6 cyl/25 spline/2 pinion/thin axles
xe falcon/5.8/4 pinion,28 spline/2.92 ratio and 2.75.
ZL fairlane/6 cyl/25 spline/2 pinion/thin axles
ea/6 cyl/
eb/6 cyl/
eb/v8/4 pinion,28 spline 3.08 ratio. and 3.27.and 3.23
ed/6 cyl
ed/v8/4 pinion,28 spline 3.08 ratio. and 3.27.and 3.23
ef/6 cyl
ef/v8/4 pinion,28 spline 3.08 ratio. and 3.27.and 3.23
HOLDEN
vk/6cyl/25 spline/2 pinion/thin axles
vk/v8
vl/6cyl/25 spline/2 pinion/3.45 open wheeler /thin axles
vl/v8/28 spline/4 pinion/3.08 open wheeler/optioned with LSD/thick axles
vl turbo/28 spline/4 pinion/3.45 LSD/thick axles
vn/v6
vn/v8
vp/v6
vp/v8
vr/v6
vr/v8
VR csv 220 got 3.70
VR GTS 5.7 GOT 3.45.
vs/v6
vs/v8
NISSAN
r31 skyline/28 spline,3.9 ratio
r31 pintara/25 spline,
Re: axel question
« Reply #13 on: May 07, 2010, 09:55:35 AM »
Ben the side bits you talk about, is that the spider gears? Cos when l spoke to Dennis Smith, thats the diff bloke up here, he said something about the vl turbo diff centre and then something about the machining of the spider gears or axles alittle. l'll try and catch up with him over the week end. lf l remember correct it was something about the pitch on the spline
Re: axel question
« Reply #14 on: May 07, 2010, 11:02:44 AM »
well im off to the wreckers to check it out:) vl turbo is 28 spline.. so that would ned to be machined.. but im gunna try the 25 spline vl standard 6cyl spider gears/ side gears
« Last Edit: May 07, 2010, 11:04:32 AM by ben »
