  • Dot Guests: 338
Author Topic: Another vanner in melb!  (Read 5963 times)
Offline toddat1200
Re: Another vanner in melb!
« Reply #10 on: May 03, 2010, 08:27:18 AM »
hey all
picked her up on saturday! WOO HOO!
will get stuck into her soon to get her on the road
whats the best way to post pics?
1980 - light blue with a white roof - registered 3 seater - horrible diff gear ratio - im guessing about a 4.6 (screamer)
stud pattern approx 4 x 90mm all round - is that bedford?
« Reply #11 on: May 03, 2010, 09:04:29 AM »
i ussually upload to photobucket then copy "img" bit to my post.. i find that easiest. screaming diff not so good:(
« Reply #12 on: May 03, 2010, 09:20:57 AM »
4 x 90 won't be right as pretty much nothing that small exists
make sure you are measuring as shown on the bottom of this link
http://www.carlsalter.com/wheel_fitments.html
« Reply #13 on: May 03, 2010, 10:42:06 AM »
I've posted this before but simply put if you upload it to your albumn here it wont get lost (unlike photo bucket) and once in your album you can just add the links to a picture in the post.
Quote from: Warren
When you go into your Album, down the bottom left you will see a "Edit" link, click on that and it will take you into the "edit Album" page, here you can create a sub album using the "add album" from the options list.
I create sub albums for common things, as you would see for the "March 2010 get together".
once I have created the sub album I then go and open that sub album, and once again the "Edit" link at the bottom left.
Click on that and you will be in the Sub Albums "Edit album" page.
Under the options Field choose add item, this will take you to another page called surprisingly the "add items" page.
You then have a box where you can type in the location of your file (or use the browser tab to find your file) and you can also fill in the caption field.
Initially you will see room for two uploads, but you can add more by pressing on the "more upload boxes", I do about 4 at once as it takes some time for the program to resize and upload them, if you have a slow INTERNET connection you might try 2 to start with as it can take several minutes to do the uploading.
I do not resize my pics, and they are usually 3 or 4 meg,  the program automatically resizes them to what you can see in my albums.
Give it a go, its not to hard and if you have any problems PM me a number and I will talk you through it.
Give it a try
