  • Dot Guests: 371
Author Topic: lead wiping?  (Read 6991 times)
Re: lead wiping?
« Reply #10 on: April 16, 2010, 08:37:56 PM »
using a sealer like fish oil or wax wont stop rustit will only trap it in the panel you need to use a good thin viscossity rust converter and then you can seal it  hope that helps guys  cheers neil
Re: lead wiping?
« Reply #11 on: April 16, 2010, 09:45:13 PM »
iv been using a 3m product that i got from an auto paint supply shop its been good so far, but i was worried about poring it into the panel crevis as it its a converter as well as disolver and says to rinse it of after conversion and as u can imagin i cant . So du you reckon safe to por in leave for 24hrs then hit it with fish oil?
Re: lead wiping?
« Reply #12 on: April 16, 2010, 11:44:51 PM »
I would use it Craig but make sure it dries before the next step. I"ve  been using rainex (recomended by Farrace Auto Rust). then finishing the panel to completion(outside) once done I will then use a penetrol/rainex solution to get into all the tight spots  this is amazing stuff apparently, again letting this dry before  i then fill with a cavity wax. just found this on the web
www.fordscorpio.co.uk/cavitywax.htm
http://mike.british-cars.de/
Re: lead wiping?
« Reply #13 on: April 17, 2010, 08:08:13 PM »
dano, is that rannex, or rainex?
rannex is a rust convertor, rainex is a windscreen product to make water flow off the windscreen faster.
my favourite anti rust product - and i used many on the van - was DE-OX-IT, worked a treat, and fast too
Re: lead wiping?
« Reply #14 on: April 17, 2010, 09:06:30 PM »
ok so , today we managed to seperate the top rusty gutter from the good lower gutter about 350mm long and 50 mm into the roof so now im making a steel panel to weld back in , do i use a glue between the two gutters and dose any one know if you can hire a spot welder to reproduce a factory finish ?
