  • Dot Guests: 21
Author Topic: Heartbreaking  (Read 4466 times)
Offline kimbosound
Heartbreaking
« on: April 06, 2010, 03:56:11 PM »
Got a hot tip on a beddy van that was recently left at the Denmark rubbish dump.....went along for a gander and found that it had a properly installed Ford disc brake front end and a ford high speed diff [ at least i think its a ford diff as the stud pattern on the wheels was ford].....what a shame.....its a 79 model and had also had a lift up rear door at some stage. Sadly all the frond end was completely rusted as were the diff housings and tubes......more photos here.....
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=19898
Re: Heartbreaking
« Reply #1 on: April 06, 2010, 04:07:35 PM »
strip it kimbo.. probly only surface rust eh:)
Offline kimbosound
Re: Heartbreaking
« Reply #2 on: April 06, 2010, 04:11:39 PM »
sooooooooooooooooo tempting Ben..........i am afraid all the bolts will just snap off .....such a shame!!!!!!......sadly it is the latest model i have ever seen.....it is actually an 80 model not a 79.....still had all the I:D plates on it.....l :'(
Re: Heartbreaking
« Reply #3 on: April 06, 2010, 04:34:07 PM »
me and mark b are about to sprip a van just like that kim that is pretty badly rusted under there.. well see how it goes and let you know,
when i had my first van there was a lwb at the wreckers.. i just took a couple of things off it.
it went through the crusher i was so distrought and kicked myself i didnt buy it and strip it for the parts!!!!
Re: Heartbreaking
« Reply #4 on: April 06, 2010, 05:01:27 PM »
gezz almost as much rust as my van
Offline kimbosound
Re: Heartbreaking
« Reply #5 on: April 06, 2010, 05:28:04 PM »
i am sure all the minor scratches will buff out
Re: Heartbreaking
« Reply #6 on: April 06, 2010, 08:51:13 PM »
for sure  ;D little panel beat here n there, bitta bog & youll be laughin kb  ;)
Re: Heartbreaking
« Reply #7 on: April 06, 2010, 09:11:29 PM »
no panel beating.. just bog:)
Re: Heartbreaking
« Reply #8 on: April 06, 2010, 10:02:07 PM »
its just a flesh wound!
see skippy! that's what happens if you have a fag in your mouth when you take out your gas tank!  ;D
« Last Edit: April 06, 2010, 10:06:53 PM by able »
Re: Heartbreaking
« Reply #9 on: April 06, 2010, 10:12:13 PM »
its got a good headlight as long as its not blown,:)
« Last Edit: April 07, 2010, 12:43:53 PM by marty »
