  • Dot Guests: 138
Author Topic: Advice on Gas Tank Removal wanted  (Read 12919 times)
Offline Worzel
« on: April 04, 2010, 07:00:52 PM »
I want to remove the gas tank, as there is a fair amount of welding to do around it.
is there a procedure for this or just turn off the valve and disconnect the wires and pipes?
Re: Advice on Gas Tank Removal wanted
« Reply #1 on: April 04, 2010, 07:18:30 PM »
last time my mate had to get his tested he just removed it like you say but i think their is a special tube of leak seal that you are supposed to use in gas fittings on cars when you re attach.
please correct me if im wrong.
« Reply #2 on: April 04, 2010, 08:17:49 PM »
Yeah that will work Worzel, once you undo the pipe, let it  drain the pipes while having a coffee, use thread sealer when re-connecting, and check it with soapy water
« Reply #3 on: April 04, 2010, 11:50:50 PM »
youll get a small discharge from any fittin you undo yor inlet valve is one way yor outlet will have a tap before the lockoff no sparkywarky things near it an dont have a fag hangin out yor mouth  ;D ;D   ;D i used to test all the fittings wiv a spray bottle of water wiv a tad of washin up liquid in it . . palmolive of course so i didnt get dishpan paws  ::)  oops soz ross didnt see yor imparted comment above hope u use palmolive too  ;D
« Last Edit: April 05, 2010, 12:09:24 AM by SkippyThBushKangeroo »
« Reply #4 on: April 05, 2010, 12:07:50 AM »
most of the fittings are self sealing or olived..i found ptfe tape woz always ok   the water n dishliquid will tell u straight away if something isnt sealed . .beware lpg is incredably totally  an 1 of th  highest of all things flammable. even static from yor curlywurlies to your nylon cacs can get it goin .1 litre of lpg mixed with the correct amount of air for combustion is equal to 24 litres of  petrol in its boom value. do not treat it wiv complaciency or disregard for it volatility.. (very very very "serious icon" inserted.) an murphys law loves its volatile propertys to be sure to be sure to be sure
Offline Worzel
« Reply #5 on: April 05, 2010, 08:12:03 AM »
thanks, i'll wait till a windy day ;)
« Reply #6 on: April 05, 2010, 10:54:17 AM »
hay skippy, fag has a different meaning in the great southern land..
having one of them hanging out of your mouth while working on the beddy takes on a whole new meaning  ;)
« Reply #7 on: April 05, 2010, 01:56:21 PM »
it would indeed be difficulterer to check the tanks date . .   ;D but id be more worried about the ol ringgear gettin chewed out or sumfing at that piont   ;D oh no  am not goin  "camping" anymore , bleat! cant kick back an chew the fat wiv uvver bugas ova beddys, an aint gonna  mention any thing bout the new headjob nor owt about butting up the rear interior ,  but ya s got me   ???  ??? on the "fag" thing sweetie ???  ???   ;)  now where did i put me ciggys  ::)
« Reply #8 on: April 05, 2010, 02:51:57 PM »
glad you brought the legendary British humor with you.
« Reply #9 on: April 05, 2010, 06:56:42 PM »
standard issue mate. . i never leave home wivout it ;) an one of the reasons i luv cruisin this site. always good karma on here. never any smartarsein  less ment n taken in jest everybody always lookin for the good  sida things an genuinely helpful one of my lifes little pleasures hangin cyber wiv u dudes, an also that the south sea poms also share their ideas an that top sense of humour i find so dear to me own heart.. cheers dears  ;D a toast to u all , the very essence of life is in abundance here oh an beddys too
