  • Dot Guests: 296
Author Topic: V6 Engine Install  (Read 36196 times)
Re: V6 Engine Install
« Reply #60 on: October 21, 2013, 08:58:24 AM »
go and find one from a VS Commodore Ecotec V6 they are like 2 mtrs long, thats the best i can suggest.
Offline Noid
  • Living the dream
« Reply #61 on: October 22, 2013, 08:25:21 PM »
I just located a place that specialized in making cables. In this case it was a marine shop, I took measurements, took my old cable in so they could reuse the fittings and they made up a new one.  From memory it cost about $50.
Offline Rotti
« Reply #62 on: October 23, 2013, 10:27:02 AM »
I second marine shops, heres a guy I use in qld....awesome to deal with!
http://www.marinecontrolsystems.com.au/
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #63 on: October 23, 2013, 06:26:45 PM »
Thanks guy's  will try the VS V6,   will also check out a boat place as well...
Julian
« Reply #64 on: October 23, 2013, 06:35:05 PM »
I took my cables to cable place too, mounted them, taped them together to get the right length and took them in and said make one out of the two ...
« Reply #65 on: October 23, 2013, 07:18:34 PM »
VN cable fitted mine due to the firewall being cut.
Offline willo
« Reply #66 on: October 25, 2013, 05:45:44 AM »
Accelerator cable????????    Can anyone give me advice on what longer accelerator cabke i can use for v6motor.  Beddie  doesn't fit ( different cable attachements ) and commodore is to short... any suggestions would be helpfull.  not sure yet if any other model commodore is longer for me to use... thanks all
Hi mate,
I used the standard Beddie cable in mine and modified the mounts at the motor.  that way I carry a standard spare beddie cable and I am covered if it ever breaks.  I used the round pivot circle thingy from the standard Beddie carby on the VT throttle body and it works a treat and it pulls from the driver's side of the vehicle.  It then had a knock on effect because I didn't need extra width on the passenger's side for a cable to wrap around without kinking.
I also used the CRS sump on mine as it allowed me to install the V6 into the hole without having to cut anything at all from behind the motor. Just widened it a little.  This was a big plus with the engineer for rego as there is a structural rib under the floor that was untouched.  Could then make up a screw together engine cover as the cabin/floor strength was intact. I also retained the original auto gearshift by using the CRS sump. Oh, and also the original gearbox crossmember and mount.
IMHO the CRS sump kit is worth its weight in gold for a Beddie V6 swap.
Neil
« Last Edit: October 25, 2013, 05:51:13 AM by willo »
Offline Noddy
« Reply #67 on: October 28, 2013, 03:44:21 PM »
I had a VP V6 Commodore fitted in the CF Bedford motorhome with Auto trans,
