  • Dot Guests: 295
Author Topic: V6 Engine Install  (Read 36197 times)
Offline SandB
Re: V6 Engine Install
« Reply #40 on: April 20, 2010, 11:43:04 PM »
Sorry Skippy,   No 10 by 10 on my van!!!!   But; there is a faint glimmer of light at the end of the tunnel!!!!    If the van doesn't sell on ebay for what I want; at the end of it's time.  She's staying right here;   Let the   "rebuild/conversion begin!!!    Didn't "Really" want t sell it anyway!!!!
May I say,   ""Welcome back you pair of Beddophials!!!"  Cheers Brian & Carole
" BEDDIED AT LAST!!"
« Reply #41 on: April 21, 2010, 12:03:14 AM »
LOL knew u didnt really want to brian  ;)   so. . . .  yor beddy must be . . . UNLEADED!!  ;D  ;D  ;D   ;D  ;D   ;D
« Reply #42 on: April 21, 2010, 12:46:05 AM »
well done there brian, hang in there buddy!
Offline matty
« Reply #43 on: August 19, 2011, 11:17:48 PM »
restarting an old topic but one which is of frequent consversation, the holden V6 motor.
the question I pose today is, which V6 and auto are you using and why.
 * the VN series 1 V6 with a 4L60 auto
 * the VN s2 and VP V6 with 4L60 auto
 * the VR V6 with the 4L60e auto
 * or the ecotec V6 (VS and onward) with a 4L60e auto
another quick little question for the v6 knowledgable, does the ecotec motor share the same block as the earlier
v6 motors, the reason I ask this question is I own a modified CRS sump and engine mounts to mount a pre ecotec v6
into a torana (similar to a bedford I hope) and I aren't sure if the steel sump of the early V6 can replace the alloy
sump of the ecotec motors..
« Reply #44 on: August 20, 2011, 07:52:51 AM »
I'm using the series 1 VN as thats what donor car I found first.
I do believe the blocks changed
« Reply #45 on: August 20, 2011, 08:38:02 AM »
I've got the VN but any of the early V6's would have done. The VN is particularly good as it had the most torque of the early V6's. I also wanted to keep the conversion as simple as possible. There were a couple of other features that owners of VN's absolutely hated but suited me perfectly due to my mid mounting it. Later models had a computer controlled transmission which is just a whole lot more hassle.
I'm pretty sure that there is not a lot compatible between the early V6 Buick and the later model Ecotecs. A good place to get that sort of information is the Justcommodores forum.
« Reply #46 on: August 20, 2011, 09:38:24 AM »
I have the VP series 2 V6, mated with the T700, the model b4  going all electronic. In the words of my mechanic, so much easier to work on then the next one up.
« Reply #47 on: August 20, 2011, 10:45:09 AM »
Gone VN s1 with VP T700 auto, only draw back seems to be with the motor rev's before it changes gear, might just be my set up ???
« Reply #48 on: August 20, 2011, 10:46:50 AM »
David, Holden say computer has nothing to do with the auto change ??? on the early model
« Reply #49 on: August 20, 2011, 10:55:33 AM »
That's a pretty standard complaint apparently but there are kits you can fit to fix that.
