  • Dot Guests: 342
Author Topic: borg warner conversion price  (Read 21400 times)
« on: March 19, 2010, 06:21:40 PM »
i rang a company today that do the diff conversions he said that if i took the standard bedy diff into him and left it for a couple of weeks it would cost $1600.00 and that hed do it inbetween other jobs then just refit it myself.
Re: borg warner conversion price
« Reply #1 on: March 19, 2010, 06:47:06 PM »
the guy here that used to do them put XA Falcon centres in and resplined the bedford axles.
so the only bedford bits were the axle tubes and axles
« Reply #2 on: March 19, 2010, 07:19:40 PM »
hey craig, what are you doing to your diff, conversion wise ?
George.
« Reply #3 on: March 19, 2010, 07:48:06 PM »
323 falcon center bedford axles and he broaches the side gears .
« Reply #4 on: March 19, 2010, 07:55:24 PM »
have any luck with bedford bearings craig?
« Reply #5 on: March 19, 2010, 08:15:04 PM »
not yet.
« Reply #6 on: March 20, 2010, 09:31:32 AM »
I have a bedford diff with the borg warner conversion already done, needs a new centre (goes but whines) and the usual bits and pieces handbrake cables are sticking, reckon the slave cylinders need replacing, standard beddie stud pattern .... I'm in North Ringwood if any one interested or I'll leave it collecting dust in the garage  ;)
Offline Worzel
« Reply #7 on: March 20, 2010, 11:10:18 AM »
http://cgi.ebay.com.au/Rear-Wheel-bearing-kit-for-Bedford-CF-Sherpa-QWB607_W0QQitemZ350299177970QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CommercialVehicleParts_SM?hash=item518f7543f2
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=1169.0
$1600 is not too expensive,
i was charged more and i provided the brooched planetary gears (i think thats what they were)
While you are at it you can get the axles and hubs drilled to HQ if you are putting discs on the front
Offline LS120
« Reply #8 on: March 20, 2010, 08:01:49 PM »
just a quick Question.. i've done the diff change over & now the speedo is out.. any way to fix it ???
i've put in a cresta 3.4:1
thanks
« Reply #9 on: March 20, 2010, 08:05:15 PM »
LS120 if ur runnin a standard bedford speedo there is an adjuster on it but it means pulling the dash 2 pieces 2 get to it. its on the side of the speedo gauge itself.
