  • Dot Guests: 338
Author Topic: wheel off set for 15x10  (Read 3939 times)
Offline project cf
  • custom vans not just for pleasure there for life
« on: March 17, 2010, 08:43:59 AM »
hi every one i need to no wat negative offset a 15x10 wheel has on a beddy or wat i can use
« Last Edit: March 17, 2010, 09:11:00 AM by project cf »
Offline bed767
Re: wheel off set for 15x10
« Reply #1 on: March 18, 2010, 08:47:00 PM »
bed767 here   I run a standard holden one tonner diff. with standard american racing 15x10 mags with 275 /60x15 tyres on my standard cfs bedford. The mags are standard holden hq offset ,i.e.3 3/4 inches.This gives about 1/2 inch clearance from the standard spring set up. Been this set up for 24 years with no scrape broblems at all.
   cheers  Brian
« Reply #2 on: March 18, 2010, 08:58:31 PM »
hey bed767, project cf proberbly wont know what a hq is, as his from the uk ;D ;D ;D
take your wheel off and run a flat edge across your brake drum, then measure from the flat edge to the nearest object, being spring hanger or inner wheel arch... hope this helps cos it realy does relate to what diff you have
« Reply #3 on: March 19, 2010, 06:26:13 AM »
for the front its 125mm offset back space
for the back i have 200mm but if you have a standard diff width use same offset as front.
depends on what diff you have.
i have a chev impala diff which is real wide then deep dish rims as well and the rims sit right to the edge of flares
Offline project cf
« Reply #4 on: March 19, 2010, 07:14:22 PM »
thanks for that been a big help cf project uk vanners
Offline bed767
« Reply #5 on: March 19, 2010, 09:11:48 PM »
bed767 again     sorry!  drum face to drum face holden hq is 1568m.m.
