  • Dot Guests: 297
Author Topic: bedford turbo  (Read 5319 times)
Offline jimsvan
bedford turbo
« on: February 27, 2010, 09:39:53 AM »
has anyone heard anyone or now anyone who has put a turbo motor in a bedford van people say it can be done i spose anything can be done really
Re: bedford turbo
« Reply #1 on: February 27, 2010, 10:50:43 AM »
Jim
Take the time to use the search function and you will find heaps of onfo here.
this link to Mr Whippys 202 Turbo was second to your post.
There are also Pics in his gallery from memory.
Offline Jeff
Re: bedford turbo
« Reply #2 on: February 27, 2010, 10:54:26 AM »
CF-UK has a very good article with photos on how to fit a 4 cylinder Vauxhall turbo, but why you would bother beats me.
Yes you are right. If one is going to the trouble of fitting a different motor/gearbox, then you may as well put your dream unit in.
A BMW 2.8 would be very nice!
Funny old life.
Offline grandad
Re: bedford turbo
« Reply #3 on: February 27, 2010, 11:14:31 AM »
ive seen one fitted with with a vl turbo motor and gearbox
Re: bedford turbo
« Reply #4 on: February 27, 2010, 03:01:10 PM »
Racking the old memory banks didn't TABU have a turbo on it??????????
Offline jimsvan
Re: bedford turbo
« Reply #5 on: February 27, 2010, 06:04:21 PM »
is there alot of work putting one in
Offline Jeff
Re: bedford turbo
« Reply #6 on: February 27, 2010, 07:14:26 PM »
It's simple enough, but yes, a lot of work to fit a different motor and gearbox.
Funny old life.
Offline jimsvan
Re: bedford turbo
« Reply #7 on: February 28, 2010, 03:26:03 PM »
is it the same work as fitting a 350 chev engine in for example need to make new engine mounts of course need wiring and computer i spose
Re: bedford turbo
« Reply #8 on: February 28, 2010, 05:50:21 PM »
i think you will find 350 chev has same engine mounts as holden 6..
Re: bedford turbo
« Reply #9 on: March 01, 2010, 07:47:36 AM »
fitting the chev in  is a fairly staight foward engine exchange, if your mechanicaly minded. The engine bolts to same mounts but you do have to use either the mount adapter of a hk holden chev to hq holden chev or after market adapter. rear crossmember has to be modified or made, same as tailshaft. The rest has to be cut or bashed for clearance, then rewire to suit. now call the engineers and be very calm as they will stress you to the max. and don't forget to change the exhaust, radiator and the lovly braking system to match your new horse power to match ;D ;D ;D all in all, not a week end job, but worth while when its completed ;)
