  • Dot Guests: 281
Author Topic: laying off the v8 conversion  (Read 5933 times)
Offline jimsvan
« on: February 24, 2010, 09:32:08 PM »
hey guys just had a major problem with my van i drove it after work to a mates house that i havent seen for a while and had a beer with him and went i left to go home reversed out the drive way the front made a weird noise i thought it was steering but i kinda didnt think nothing of it till i drove down the road slowly and it sounded like a wheel bearing thought i would try nurse it home got right near the end of the street and thought nah f*** this ill stop and get a tow truck home but as i was pulling over there i see a wheel bouncing down the road i was like oh f this f that went out and saw the damage thought it didnt do any panel damage untill i grabed me mates fwd and then notticed on the left wheel arch and the edge of passenger door so i will need a new door so anyone in melb that has a spare door preferably a good one not rusted out let me know but i guess i have to lay off the v8 for now till i fix this problem up or i may even just pull it off the road and do the hole lot still registered so i can still pay reg
Re: laying off the v8 conversion
« Reply #1 on: February 24, 2010, 09:48:43 PM »
Hey jimbo, do you know what happened, what caused it ? same thing happened to me in 01, I was leaving a meeting, drove out of the carpark and noticed a clunking noise, I to thought of a bearing, I drove home about 5ks, got out at home, and found all but one nut missing, some little magot had tried to lift my new mag wheels, I must of interupted them half way through, being on the left I never noticed anything before I drove off. Driving off and driving like that snapped off some of the studs. Broken studs was one reason I decided to go 4 wheel disc brakes, and from there I decidded to go all late model running gear.
George........
Offline jimsvan
« Reply #2 on: February 25, 2010, 06:43:03 PM »
yeh pretty much the same thing except i was reversing the van out of me mates drive way and i heard a clunk thought it was steering only till i started driving it slowly and heard metal scraping then i new something wasnt right so i went to stop and i had f*** all brakes so i was at the end of the street where me mate lives and thought na f*** this ill turn around and leave it at me mates joint till in the morning and get me tow truck driver i know well that only charges me 50 for a tow but when i went to turn round that when the left hand front gave way brock stub axcel but it also broke the calipar aswell have abit of panel damage i do need a new door and i think i may need to either bash or cut out some metal and put new one it doesnt look too good but brother is a beater so ill let him do the work, i will take a photo of it and add it to me gallery so everyone can see it also i did the hood lining i will take a photo of that too so people can see what i have done since i have brought it but i have decided tho still buying another van that has  a v8 in it 350 chev or 308 and ill just transfer all the shit over to mine but while im at it ill put all new bull joints etc in the front
« Reply #3 on: February 25, 2010, 07:18:36 PM »
Hey mate, thats not good news
I'm guessing that it is a disc brake conversion on the front, and the stub has snapped off?
Sounds like someone has had the stub machined, in which case i'd be having the remaining stub replaced too as it'll only be a matter of time.. and next time you may be travelling faster than you were this time..
But yeah, get us some pics, it not only helps describe potential problems, but also helps with preventions
Good luck with the repairs
« Reply #4 on: February 25, 2010, 07:21:25 PM »
far out lucky u wernt goin 80kms or higher,
did u say the stub axle snapped?
if so was it machined down for the disk brake conversion 2 be fitted?
if so weve had a big debate on this subject before .
where a member had the machined stubs and thought they were good and safe as.
but its clearly not good and safe as if thats the case,
let us know if its ok.
regards marty
« Last Edit: February 25, 2010, 07:25:26 PM by marty »
Offline jimsvan
« Reply #5 on: February 25, 2010, 07:44:10 PM »
yeh the stub axle snapped must of snaped as i was reversing out and when i heard a clunk i thought it was steering but when i slowly drove up the road i heard the clunk again got out of the van to inspect couldnt really see anything was dark at the time and then i thought ill just put home but got to the end of the street and i could hear metal grinding so i thought nah stuff this ill leave it at me mates but didnt make it that far back but yeh im glad it happened there not on the fwy as i went on a fwy to get to me mates house and would have gone back home on the hwy wouild have fliped the van and posabily me in hospital or dead real scary shit lucky i was only driving slowly i didnt feel much of it just saw a wheel bouncing down the road its at me mates machenic work shop atm his going to look over it for us keep use inform but definately was a clean snap broke the calaper aswell
« Reply #6 on: February 25, 2010, 07:57:55 PM »
yep those pics are needed. do you know if they were original bedford stub axles or did someone fit the HQ ones?
Offline jimsvan
« Reply #7 on: February 25, 2010, 08:09:03 PM »
im not sure the guy i brought it off said it was hq stud pattern but i will get pictures
« Reply #8 on: February 25, 2010, 08:58:57 PM »
hey jim if you get a chance if you can take measurements of the stub axel width where the bearings sit (2, inner and outer) and also the diameter of the thread for the bolt on the end. if i knew these measurements i could tell you which stub axel it is and if its been machined and where.
and! i have a passenger door especially for you!.. i have not been wanting to split these great doors up but now i have good reason. drivers side for my van.. passenger for yours:) ill pm you
« Last Edit: February 25, 2010, 09:00:41 PM by ben »
Offline jimsvan
« Reply #9 on: February 25, 2010, 09:19:59 PM »
what needed to be machined does the front need machining to fit hq stud pattern because maybe they just put the wheels on and hope the best i dont really know
