  • Dot Guests: 362
Author Topic: lifting the van to remove engine  (Read 12479 times)
Offline jimsvan
« on: February 23, 2010, 09:19:39 PM »
just after an easy solution on how to remove me engine for me v8 conversion need to know how people lift the van up and remove the front end and engine and the lot removes while the van is still up
Re: lifting the van to remove engine
« Reply #1 on: February 24, 2010, 12:46:10 AM »
you place a thick bit of box tube long enough to go under both sides of your chassis rails at the very front of your beddy's engine bay.  i have a 202 so i had to have the box steel on its side so it did not hit the water pump...
then you simply lift it using some strong chain and a engine crane.
ofcourse you take all safety precautions and make sure you have unbolted everything. ;)
i was asking the same question a few months ago and their was a large thread about it....
i had a quick look but could not find it.
« Reply #2 on: February 24, 2010, 01:10:59 AM »
is this it? if it doesn't work try "engine replacement" in technical forum. Dan
www.mamboteam.com
 Bedford User Group - Australia
 Featured VansGalleryForumHome
 Home  Forum  Technical Driveline engine replacement Wednesday, 24 February 2010
  Main Menu
Forum
Old BUGA Forum
Chat Room
DIY HowTo's
CF Facts & Figures
Contact Us
Featured Vans
Links
Downloads
User Menu
User Form
Welcome Dano.
Total time logged in: 5 days, 12 hours and 27 minutes.
Profile
Messages (111/0)
Recent Posts
Updated Topics
Members List
Member Map
Logout
Recent Posts
How did you fi...
What have you ...
lifting the va...
installing fla...
Brisbane get t...
Rego :
wanted bedford...
Best mash-up e...
Ben's fibergla...
some ugly some...
Bailey Channel...
wanted body ki...
Indicators
on Ebay
Beddie Van for...
 BUGA Community
  Hey, Dano, you have 111 messages, 0 are new.
Show unread posts since last visit.
Show new replies to your posts.
February 24, 2010, 01:07:34 AM
Search:     Advanced search
16970 Posts in 1538 Topics by 601 Members
Latest Member: arron
  BUGA Community
  Technical
  Driveline
  engine replacement Dano and 0 Guests are viewing this topic. « previous next »
Pages: [1] 2 3 ... 6
 Author  Topic: engine replacement  (Read 1641 times)
Just streetable
 Offline
    engine replacement
« on: March 19, 2009, 09:38:57 AM »
gad,y all hope you are all well...
mr rud put a little extra funds in the bank and i decided to grab me a red 202, m20 and a shifter to match from the wreckers... i also ordered a complete seal kit while i had the dosh.
a few questions arise... i notice you fellas lifting the entire front of your beddy's and rolling out the motor and gear box  on the front end and i was wondering if that approach is 100% necessary?
i have to take off the three speed gear box on the old 186 because i need the bell housing for the four speed so if its just the motor is their enough tilt room to just jack up/wheel stand and with the help of a small engine crane slide the motor out?? (i have gutted the front of all components so their is no radiator or anything)
and would one bother replacing welsh plugs? or if they look fine leave them?
the 202 had "150" (or within 5 of) on compression test (cold) is that normal for a second hand red 202?
any other advice would be appreciated. i have never done a engine change before and i suspect their is a few tricks and hints learned from experience...
 Report to moderator    Logged
http://whatreallyhappened.org/
craig
Global Moderator
Apprentice Mechanic
 Offline
canning vale western australia
     Re: engine replacement
« Reply #1 on: March 19, 2009, 10:13:36 AM »
lifting the van up might look hard but its not , its only few bolts ;;;;;;;;;;;;;;;;;;;;;;just remember to put em all back.lol
its not broken down.......... its a chance to improve it.
Your a bedford owner ....adapt overcome..
Worzel
Just streetable
 Offline
« Reply #2 on: March 19, 2009, 11:13:39 AM »
yeah, it's the easy way, just remember- safety first.
don't get under it!
some photos in this thread....
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=80.msg5116#msg5116
I used an engine hoist and tow straps, because they wom't scratch the piant.
I bought a couple of bigger axle stands, but still not big enough so put them on SOLID base of redgum blocks, and put the g/box crossmember bolts back in to lock the stands in place.
The beddy is light without the motor and crossmember.
I was a bit nervous before hand, but it went well solo, just don't be in a hurry and drain everything first
« Last Edit: March 19, 2009, 11:21:34 AM by Worzel »  Report to moderator    Logged
Just streetable
 Offline
« Reply #3 on: March 19, 2009, 11:34:54 AM »
thanks guys!
so i just put the solid bar back on (the one the radiator bolts too) have the new motor all painted up and ready and then lift with a hired crane from that solid bar after i have undone the bolts holding the front end to the chaise (is that correct spelling... ow well you know what i mean) , unbolt the old 186 lift it off, bolt new 202 in and roll back under the beddy.
yes.... and remember to do up the front end bolts
sounds simple but i would do it with two people.....
is it pretty easy to line up the front end bolts as you lower the beddy back down or does it take a few goes?
Global Moderator
Apprentice Mechanic
 Offline
« Reply #4 on: March 19, 2009, 11:38:58 AM »
Able have a look at this thread Motor Change for a bit more info.
And look at the trolly John Abbot made to make it even easier
A gantry and block and tackle works as well -  see eddys albumn
Oh and the "search" tab is your friend
« Last Edit: March 19, 2009, 11:42:28 AM by Warren »  Report to moderator    Logged
Just streetable
 Offline
« Reply #5 on: March 19, 2009, 02:53:41 PM »
the beddy is stuck in the garage so i cant get a gantry in there....
i will have to go with the method John Abbot went with but i haven't the money to make trolley.
seems straight forward.... ill work out a cheap option for the lack of trolley.
Global Moderator
Just streetable
 Online
« Reply #6 on: March 19, 2009, 04:20:34 PM »
Hey Able....At a pinch mate ,you could wire a trolley- jack to the end of the gearbox so it wont come off and that way you would have a set of wheels at the back and the beddies wheels at the front and roll it out. Just a thought, when you are undoing the 4 bolts that hold the crossmember to the chassis,they sometimes can be a bit hard to wind out, so you may have to wind them in and out a bit to eventually get them out. Let us know how you go.! cheers...johnno
Just streetable
 Offline
« Reply #7 on: March 19, 2009, 04:43:17 PM »
thanks john for the idea!
i have a trolley jack so that will have to do!
Apprentice Mechanic
 Offline
« Reply #8 on: March 20, 2009, 09:07:12 AM »
you can even just skid it out on a piece of ply or something. youll figure it out bro.
Brett
Full of bog
 Offline
« Reply #9 on: March 21, 2009, 02:57:15 AM »
i wish i did the welsh plugs while the engine was out cuase it was hard changing them once its bolted in.
Why on earth would you want one of THOSE for
« previous next »
Jump to:  Please select a destination: ----------------------------- General Category ----------------------------- => Featured Members => Introduce Yourself => CF Bedford Chat => General Discussion => Cruises and Events => Members Rides => CF Bedford Art ----------------------------- Technical ----------------------------- => Maintenance => Buying a Bedford => Driveline ===> Disk Brakes ===> Diffs => Electrics, Audio and Security => Exteriors and Interiors => Campers => Miscellaneous Technical ----------------------------- Classifieds ----------------------------- => For Sale ===> Found for sale => Wanted ----------------------------- Website ----------------------------- => BUGA site information => Site Feedback => Test Board
   Powered by SMF 1.1.8 | SMF © 2006-2008, Simple Machines LLC
Joomla Bridge by JoomlaHacks.com
Loading...
   © 2010 Bedford User Group - Australia
Joomla! is Free Software released under the GNU/GPL License.
Design by Mamboteam.com! / Template Downloaded from Joomla.lt
« Reply #3 on: February 24, 2010, 09:43:53 AM »
Hi Jim...Here are some pics of an engine transplant that Craig and i did on a previous members van. It was the first one that i had done ,and even though it looks a bit daunting,its the way to go.
this is the lifting bar i made up. Once you have removed your radiator,it will sit under the narrowest part of the sub-frame right up the front.
« Last Edit: February 24, 2010, 09:49:13 AM by John Abbott »
Offline jimsvan
« Reply #4 on: February 25, 2010, 07:48:17 PM »
think i might go that approach i have me mates workshop he has three hoist so when he isnt busy i may just see if i can use one then but if not im going to go that approach thanks for the tip john
« Reply #5 on: February 25, 2010, 08:01:18 PM »
No probs buddy. If you want to make up a engine trolley like the one we are using in the pics let me know and i will get some measurements and pics for you. ;D ;)
« Reply #6 on: February 25, 2010, 08:20:48 PM »
the rolling jack at the back of the gearbox worked great for me on the way out and the way back in...
i just wired it with a coat hanger and dropped it down and out she come. if the jack went on a angle i pushed it true with the broom stick. (safety first)
a old skate board will even do but you will have to lower the gear box down onto the board if you do not own a rolling jack.
no offense to your most excellent trolley john'o but i would rather put the $50-100 into beddy parts  ;)
Offline jimsvan
« Reply #7 on: February 25, 2010, 08:27:43 PM »
but how does the jack at the back of the gear box work lifting the van up and keeping the van up to remove motor
« Reply #8 on: February 25, 2010, 09:02:25 PM »
no no no.
you used the bar and engine crane for the lifting but you will have to stabilize the motor and front end when you are pulling it out.
the front end with the motor and gear box are back heavy and will want to tip backwards.
john made up a trolley but i was trying to tell you that a simple rolling jack or skate board will do the trick and you probably have these things already.
i cant justify making up a trolley for something you will hopefully only have to do twice (out and back in).
here is how i did that.
« Reply #9 on: February 25, 2010, 09:12:42 PM »
i will take some example pics tomorrow and do a run down of the procedure if you like?
i wont actually lift it as i just got my front end back under the other day... if you were asking a few days before you did i would have been able to do a blow by blow pic and explanation thread.
maybe we should be all thinking like that whenever we do something to our beddy's just in case.
« Last Edit: February 25, 2010, 09:14:52 PM by able »
